Author Topic: New version of Room EQ Wizard  (Read 18688 times)
« on: March 11, 2008, 02:35:47 PM »
Got this email today:
"Hello richidoo...
REW (Room EQ Wizard) Version 4.11 has been released today with a few more new features and a few bug fixes as follows...
New features:
    * Level of sweep on left ref channel automatically adjusted to get ref input to -6dB FS
    * System delay measurement compensates for measurement bandwidth for sweep end frequency >= 200Hz
    * Added label to show distance equivalent to the System Delay
    * Data import tolerates a mixture of decimal delimiters
Bug fixes:
    * Start time of captured data on scope plot was incorrect when using left channel as ref
    * Meters were not being disabled properly when the sig gen or spl meter stopped
    * When REW was used with a Creative X-Fi the signal generator would only work once
This in addition to the Version 4.10 that was released a few days ago.
You may wish to download the latest version from our Downloads Page at the Shack:
http://www.hometheatershack.com
All the best!
Home Theater Shack"
I am still on version 3!  :shock:
miklorsmith
Re: New version of Room EQ Wizard
« Reply #1 on: March 11, 2008, 02:59:18 PM »
Way cool, I'm about to embark on a new measurement series.  I'll make sure to use the new stuff.
« Reply #2 on: March 11, 2008, 05:05:19 PM »
...  and the big new feature, RTA capability.
« Reply #3 on: May 02, 2010, 04:37:39 PM »
Another new release of REW. Version 5.0 Beta is available now.
http://www.proaudioshack.com/forums/forum-announcements-news/28116-rew-v5-beta.html
From the proaudioshack.com post:
V5 adds a number of new features, including:
New user interface
Phase, Group Delay, Step Response and Spectrogram plots
Phase wrap/unwrap, IR minimum phase conversion, IR delay calculation and adjustment
Separate windows for overlays, RTA and EQ functions
New algorithms for EQ adjustment offering exceptional tracking of target responses
Predicted effects of EQ on the impulse response and waterfall can be viewed in the EQ panel and can update live as filter settings are adjusted
"Modal" filter setting for parametric EQ filters to aid in correcting modal decay
