Author Topic: Relatively Inexpensive RCA/RCA Digital Coax?  (Read 5033 times)
Offline James Edward
« on: June 14, 2023, 01:00:29 PM »
My friend is going to need a digital cable; he’s not an audiophile but loves his music. Anything in the fifty dollar range these days getting positive comments or buzz?
I also remember reading that too short a length is not recommended- does that sound familiar? Something about causing ‘reflections’.
FWIW, I use the Kimber Illuminati D-60, and really like it, but it’s out of his price range…
Any thoughts appreciated.
Esoteric K-07X
Offline GDHAL
Re: Relatively Inexpensive RCA/RCA Digital Coax?
« Reply #1 on: June 14, 2023, 01:22:43 PM »
I absolutely have a recommendation. Belden 1694A. Get it from blue jeans cables. I've used it (still have it although not installed in my system) and can vouch for it. And yes, there is a minimum distance to avoid. I forget the precise distance, but if you're over 2 ft you're good. Most folks by a 3-ft cable at minimum.
Best.
Hal
http://halr.x10.mx/other.html
« Reply #2 on: June 14, 2023, 04:38:34 PM »
I recommend 1.5m as a good sounding length.  Sounds better than .75m (good) and 3' (not as good).  The Canare 75 ohm RCA that BJC uses are great connectors.
Offline GDHAL
« Reply #3 on: June 14, 2023, 05:09:39 PM »
Googling supports the 1.5 meter minimum. Good thing I've always used 6 *feet* for my digital interconnect.  :thumb:
EDIT I recall the topic of minimum digital wire length being discussed on audiogon awhile ago. I cannot readily find the topic. I know Almarg weighed in and presented a formula of sorts which included some nyquist numbers. My memory seems to recall a number close to 2 feet. I could be mistaken though, and google seems to like 1.5 meter or more.
« Last Edit: June 14, 2023, 05:23:04 PM by GDHAL »
« Reply #4 on: June 14, 2023, 08:24:25 PM »
Thanks-I’ll have him order a 5 foot length- BJC goes by the foot… I’ve also heard that the Canare connectors are true 75 ohm.
Esoteric K-07X
Offline Folsom
« Reply #5 on: June 15, 2023, 11:05:20 AM »
I go 6ft.
The BJC cable is good but be warned their canare connectors do strip plating. You do not want to take it on/off very much.
Offline GDHAL
« Last Edit: June 15, 2023, 11:44:20 AM by GDHAL »
