Author Topic: Quicksilver MX-190 Owners  (Read 3213 times)
Offline Sir Cut Bored
  • Newbie
« on: June 30, 2022, 04:18:50 PM »
New to the forum. . . and hoping to find someone who currently owns a Quicksilver MX-190. I'm working on with a missing original power switch. This was a three position OFF ON ON rocker, which are currently extremely hard to find. My hope is that a current MX-190 owner would be willing to unscrew their front panel and tell me who the original manufacturer of the switch was. A bonus would be a photo of the wiring to the switch. Thanks.
Re: Quicksilver MX-190 Owners
« Reply #1 on: June 30, 2022, 04:36:15 PM »
Welcome to the forum!  :thumb: I was on the quicksilver website and your amp was manufactured between 1981–1985. So I can see why parts availability might be an issue. We have a couple of guys here who may have knowledge of where to source that switch or an appropriate replacement. I’ve never dealt with Mike Sanders, but maybe you could send him an email as you have one of his vintage amps.
« Reply #2 on: June 30, 2022, 04:53:39 PM »
Carling makes a DP3T ON/ON/ON switch that may work for you.  It depens upon the configuration.  With these typ of switches leaving one position un wired would give you a OFF/ON/ON switch.
I assume the first ON position was for filaments, is that correct?
https://www.mouser.com/ProductDetail/Carling-Technologies/TIGE51-6S-BL-NBL?qs=2TMTlEbebpKUffoydyDC9A%3D%3D
  • Newbie
« Reply #3 on: June 30, 2022, 05:15:11 PM »
Thanks for the welcome Nick. I should have mentioned that I've corresponded with Mike Sanders and, unfortunately, he doesn't recall the manufacturer of the switch.
Correct, the first on position is for the filaments, and the second position is for the B+. Hadn't considered an ON/ON/ON, but that sounds like a possibility. The specific Carling model you linked to is too large for the existing panel cutout, and I'm not quite at the point of cutting into/modifying the original aluminum faceplate (though it may come to that). The cutout is 17mm x 31mm rectangular.
« Reply #4 on: June 30, 2022, 07:09:34 PM »
Rebuilding/repairing older gear can be a challenge.  Sometimes a guy's gotta do what a guy's gotta do.  A good, sharp file, 10 minutes (after masking or removing the faceplate) and careful, patient work and it "may" work for you.
Whatever you choose to do, good luck!  :thumb:
« Reply #5 on: June 30, 2022, 11:46:35 PM »
Pls keep us posted if you can get this to work. Modifying a chassis can be a bit challenging.
« Reply #6 on: July 07, 2022, 09:43:05 PM »
CCB...
Have you been able to make any headway on this problem?
