Author Topic: Speaker Ground pigtail  (Read 3886 times)
« on: April 27, 2022, 11:09:02 AM »
  Anyone remember who made them. About 2" long white cloth covering, copper hook connector ??? Connect to neg binding post at speaker Used the m recently and not removing them. Need more HELP ???
Re: Speaker Ground pigtail
« Reply #1 on: April 27, 2022, 11:40:00 AM »
  Found them. Audio Prism EVS IMHO a must have tweak. Go for it. Not a dealer for them.
« Reply #2 on: April 27, 2022, 11:48:02 AM »
Is this them?
They were call EVS Ground enhancers.
Review here:
https://www.hifizine.com/2011/06/evs-ground-enhancers-a-collective-exploration-of-a-tweak/
We had a tread about them here:
https://www.audionervosa.com/index.php?topic=2646.msg29055#msg29055
And another one on AC:
https://www.audiocircle.com/index.php?topic=87809.0
If I am not mistaken, marketing if these was eventually taken over by AudioPrism, the folks better know for making the Quiet Line devices.
But good luck finding any of them them as I believe the company closed up shop.
« Last Edit: April 27, 2022, 12:07:56 PM by tmazz »
« Reply #3 on: April 27, 2022, 12:24:42 PM »
I was just looking at the AN thread and it contains a link to some DIY instructions for building your own version of the ground enhancers.
Offline ejk
  • Did I say no dropouts ?
« Reply #4 on: April 27, 2022, 12:49:54 PM »
Is this them?
Review here:
I had them. They worked very well.
Offline ejk
« Reply #5 on: April 27, 2022, 12:51:00 PM »
Hah, I even started the thread
Offline dflee
« Reply #6 on: April 27, 2022, 06:10:40 PM »
Maybe somewhat off topic but:
Would something like the ground pigtail work on the ground connection located on the Fyne 501SP?
Don
« Reply #7 on: May 05, 2022, 01:00:10 PM »
  Yes Guy's that is the one. Still in business. No make another design. Liking the result.
« Reply #8 on: May 05, 2022, 01:44:30 PM »
I still use mine. Try on the amp end, then try on the speaker end. Also try on the + lead separately from the - lead. Results vary in each position. Since my preamp inverts (tubed) I wound up with them at the speaker end on the + lead (best to my ears).
Offline ejk
« Reply #10 on: May 29, 2022, 02:28:52 AM »
Is this them?
Review here:
Me too. Probably at least 12 - 15 years ago. As you said, they worked very well
« Reply #11 on: November 15, 2022, 10:57:44 AM »
Don
   Yes.
