Perhaps my editing screwed up the message. My point was that the rating of a resistor is within that % over the entire lifetime of the resistor. So theoretically if a resistor has an x% tolerance it can come off the assembly line at +x% of its rated value and shift to -x% overtime and still be with specs. My experience with this has been with more run of the mill resistors. It seems from your later posts that you have not experienced this with the ones you have used. If the is the case I certainly yield to your expertise in that area and will modify my comment to say that unless you use carefully selected high quality parts, value shifts can cause inaccuracies over time. (And that does not have to mean super expensive tight tolerance resistors, just high quality)
And on I certainly hope you did not take any of what I said as a negative comment on your posts. Quite the opposite I was trying to highlight what I saw as at least one of the reasons why it is so difficult to get dead on right as opposed to just throwing something together that is just close enough to get out the door and on the market. Guys like you and Dave really sweat the details and are few and far between. One of my biggest career regrets is that although I started out as an EE, I quickly got tracked into the management and financial end of the business and although I used my engineering knowledge through the day I retired I actually got to spend very little time doing actual design work. As a result I know
W enough to be dangerous.
Even though I dont have the level of detailed that you guys do, I know enough to have a deep appreciation for your expertise and what it took for you to get there.
No sweat on this end Tom. All is good here. I appreciate the clarification and your findings and I have also noticed variations of a questionable brand or two; but been too long to remember. I have not had any problems with mills except a very rare noisy 5 watters. All seems to be well with copper leaded Resista, Holcos, Vishay, but I did have a little problem with the new PRPs with initial tolerance variations. Haven't had enough time with them for a longevity study either. I stay away from Caddock 132s, a metal oxide type, and a bland sound.
For general consumption, A + to - 1% variance will alter the RIAA in my circuit in the less than 0,1 dbs range. Three resistors are crucial in the RIAA network, plate, R1, and R2, as listed in my link based on Stanley's calculations. The good resistors seem to always measure within 0,25% or so using a Textronix meter. Resista, Holco, vishay resistors seem to measure less than 0,25% between dozens of resistors, pretty reliable. I see Michael Percy has Vishays for $12.00.
Thank you for the appreciation Tom. I cannot calculate all the R&D, sophisticated, proprietary listening test since 1980 or sooner. And for no pay; out of my own pocket. I have even tested if wires transmit in the audio realm and at what frequencies.
Cheers and all the best Tom.
