Author Topic: If it were you  (Read 3380 times)
Offline dflee
If it were you
« on: December 11, 2021, 05:58:34 PM »
I have truly balanced (at least according to their lit) dac, pre and amp with no balanced cable to be had.
Which XLR to RCA would you go with to try out the balanced sections of the equipment?
Cardas makes two versions along with Neutric or Moon. Is there a difference sound wise or should I just look at the el cheepo adapters?
Don
Offline Jack
Re: If it were you
« Reply #1 on: December 11, 2021, 06:00:45 PM »
Just buy the Neutrik's from one of the pro audio stores.
Vista Phono II
Jays Audio CDT3 Mk III
Supratek Cabernet
Kinki Studio EX-B7's
Holo Audio May KTE
Auralic Aries G1
Verity Otello
(2) Rythmik F12SE
TWL PC's
Audio Envy IC, PC, SC
Inakustik USB, I2S
PSA Stellar P3
Uberbuss
Re: If it were you
« Reply #2 on: December 11, 2021, 08:24:42 PM »
Don
The Moon units are quite good.  The Neutriks are hard to find in stock anywhere and the Cardas are great, but bank.
Offline Jack
Re: If it were you
« Reply #3 on: December 11, 2021, 09:27:21 PM »
B&H and Parts Express both have the Neutriks in stock but no on Amazon.
Vista Phono II
Supratek Cabernet
Holo Audio May KTE
Auralic Aries G1
Verity Otello
(2) Rythmik F12SE
TWL PC's
Inakustik USB, I2S
PSA Stellar P3
Uberbuss
Offline dflee
Re: If it were you
« Reply #4 on: December 12, 2021, 02:41:19 PM »
Thank you Gents.
For just wanting to see if there is a sound difference, the Cardas do look nice but are three times the Moon price. I think I'll try the Moon for now. Next question would be which connection to try first. Dac to pre or pre to amp?
Don
Re: If it were you
« Reply #5 on: December 14, 2021, 12:30:29 PM »
  Do the entire system approach. If gear is a balanced design throughout balanced is the way to go IMHO.
