Author Topic: should I get better Ethernet cables?  (Read 11149 times)
Re: should I get better Ethernet cables?
« Reply #15 on: May 31, 2021, 07:01:37 PM »
Charles, a question for you that is somewhat off topic , but still related to this thread. If I am correct when you talk about using the TWL Ethernet cable, you are using it as a digital interconnect between components, correct?
So my question is this, when Innuous provides ports for Ethernet connections between components, are the running standard Ethernet protocol signals over them or is it just an RJ45 connector that is used to send a proprietary digital signal over a standard Ethernet cable?
Or in other words, is the signal that comes out of they port the same protocol that is used to talk to routers and computers, or is it an audio specific digital format?
Just curious. :-k
  I use the Ethernet cable in a dedicated I2S connection between Transport and DAC. Innuos runs standard Ethernet cable from Router to server. My comments relate to cable between transport and DAC not from Router to server. There I use a shielded 12' Monolith Cable.
Thanks, that is what I thought.
« Reply #17 on: May 31, 2021, 10:29:34 PM »
« Reply #18 on: June 01, 2021, 12:45:09 PM »
Just curious. :-k
 As an aside just buy an iFi wall wart for the Router. Gonna be a happy camper.
« Reply #19 on: June 01, 2021, 01:02:47 PM »
Just curious. :-k
Thanks, Charles. You’ve given me very good advice in the past. The ifi is $99 on Audio Advisor. When I’m ready to crawl around on my hands and knees, I’ll check what the dc voltage is on the ASUS router
« Reply #20 on: June 02, 2021, 09:06:52 AM »
Just curious. :-k
+1 on the router supply.
« Reply #21 on: June 02, 2021, 09:54:50 AM »
Just curious. :-k
Dave, I was wondering what you’d say about this. My ASUS is a pretty decent wireless router…probably paid about $170 for it. The factory power supply is a 19v, 2.37A  LPS. At Audio Advisor, the highest dc voltage ps is 15v. That’s for the $99 version Charles was talking about. I’ll search some more, but likely I’d not want want to pay more than $100 for this experiment.
« Reply #22 on: June 02, 2021, 11:03:25 AM »
Not finding any lps around 19v that is described as ultra low noise and reasonable as to cost. Suggestions welcome…
« Reply #23 on: June 13, 2021, 06:27:02 PM »
I ordered a Supra 2 meter Ethernet cable on ebay last night. Should have it by Friday. Also sent an email today to Acopian regarding which of their power supplies I might be able to use for my 19v  2.37A  ASUS router. Once I get an answer from them, I’ll see if I can find a good deal on ebay
« Reply #24 on: June 17, 2021, 10:43:02 PM »
The Supra Ethernet cable arrived today (thanks Scotty!) and I placed it from the wall to my ASUS router. I wasn’t expecting much, but was hoping for a lot though! Well, it was a heck of an improvement. Again, it quite surprised me. Now, some months back, I had switched cable providers so I receive a signal from a tower to a new dish on my roof with new wiring down the wall and a new connector as well.
The sound is richer and more detailed. As the reviewers might say, more “fleshed out”
I only spent about $60 on eBay and it was money very well spent. The next thing I want to do is get an Acopian linear power supply that is adjustable to 19V. I will use that as the power supply for my Asus wireless router. I’m hoping to be able to get it for under $100 on eBay.
Well, back to enjoying some good tunes 🎶🎶
« Reply #25 on: June 18, 2021, 09:51:35 AM »
Was the Supra cable you got on eBay the CAT 7 or CAT 8?
« Reply #26 on: June 18, 2021, 10:17:01 AM »
Tom, I got the CAT 8 per Scotty’s link. Glad I didn’t fiddle with trying a Blue Jeans
or a Monoprice. They might have been sufficient, but I’m quite happy I went straight to the Supra  :thumb:
http://www.jenving.com/products/view/cat-8-stp-patch-frhf-blue-2m-1001908639
« Last Edit: June 18, 2021, 10:33:11 AM by Nick B »
« Reply #27 on: June 18, 2021, 12:57:13 PM »
  I recommended the Monoprice as I thought it sounded better in my system than the Supra.   Glad now you realize a difference can be had. That is all that matters. Enjoy the new sound.
« Reply #28 on: June 18, 2021, 01:47:33 PM »
Thanks, Charles. I should have inquired further. Yes, quite a difference indeed  :thumb:
Offline toobluvr
« Reply #29 on: June 18, 2021, 01:52:16 PM »
https://www.telco-data.com/cat5e-vs-cat6-vs-cat7-vs-cat8/
According to this article CAT 7 is not standardized, so there will be construction and connector differences across manufacturers.  If you need faster throughput over short distances, goto CAT 8, as that is its only advantage over 6A.    Otherwise, CAT 6A is fine.
