Author Topic: CD Player and two DAC comparisons  (Read 5808 times)
« on: May 05, 2021, 05:22:00 PM »
A friend brought over a very highly regarded Monarchy 24 tube DAC the other day. I also have the heavily upgraded Modi 2 and upgraded NAD 521Bee, both of which I upgraded.
Amazingly, the three sounded so close we could not tell the difference. This is the upgraded Modi 2 that upstaged the highly regarded Border Patrol tube/SS powered DAC. In a couple or 3 weeks I will be comparing a Denafrips DAC.
What amazed me was that I had not compared the Player/DACs while performing the upgrades; The first comparison
occurred last evening (exception Border Patrol sometime back). The stereo system is extremely transparent, so any sonic differences and/or problems would be perceived. This is verified by several different methods of altering my systems performance.
1. Changing just one leg of speaker wires from ten 18 gauge wires per leg to 11 per leg is perceived.
2. Adding or subtracting 1/4 inch of a turn on a 600 watt 10 mh crossover inductor is perceived.
3. Changing the resistance of a crossover resistor by 1/100,000th or less of an ohm is perceived.
4. Rotating a speaker by 0,5 mm pen width is perceived.
Thus masking, which can occur due to venue/system problems, and affects inner detail, tonal quality, soundstage
etc, is virtually eliminated.
We also compared my ethernet cable (14' long) to the Supra (25' long cable), and the Supra cat 8 lost. That was interesting since my Supra USB 3 meter cable from computer to DAC clearly beat three other USB cables, one $600.00 or so.
« Last Edit: May 07, 2021, 09:29:06 AM by steve »
Re: CD Player and two DAC comparisons
« Reply #1 on: May 10, 2021, 11:24:51 AM »
  Steve in general not giving away your secrets what upgrades ? Power supplies ? ????
« Reply #2 on: May 10, 2021, 09:38:31 PM »
For the CD player, it was by-passing the 6db analog gainstage (gain of 2) to the output. Almost every preamplifier/ amplifier combo has plenty enough gain. The cheapo analog gainstage does nothing except degrade the sound.
Power supply and internal parts, but there is more involved. Thanks for respecting my privacy. :)
« Reply #3 on: May 11, 2021, 08:07:24 AM »
When people hear things I can't, instead of doubting, I simply chalk it up to different hearing abilities.  Years ago Danny Richie was talking about hearing the difference in black wire insulation compared to red.  My ears just aren't sensitive enough for such nuance.
But when we get into something like a quarter turn on a big inductor, or .000 01 of an ohm, I'd think that you have that much variation or more simply in the contact points in on/off switches, or input selectors, or volume pots.  I've learned not to doubt that others hear things I don't, but the explanation of 1/100 000 of an ohm or .001% change in an inductor don't seem like a likely reason for change in sound.  Most of us don't hear a 1 dB increase or decrease in volume.  And +- 3 dB has sort of been an industry standard for decades.
I'm not doubting your conclusions.  But I'm curious how you arrived at determining a difference in such small changes? Shoot, I hear things different from night to night... could be what I ate, or allergies, or something my wife said.   I do think my state of mind affects my perceived hearing.
« Reply #4 on: May 11, 2021, 08:37:03 AM »
 Great idea. I have asking for years why does a CD player need a gain section when using a preamp  ? Your experience and hard work deserve a fee.
« Reply #5 on: May 11, 2021, 08:39:53 AM »
   All good points. If one truly knows the sound of their system a difference can heard. If not then change made is not worth keeping.
« Reply #6 on: May 11, 2021, 10:39:56 AM »
Hi Scott,
Actually it is a1/4" of a turn on the inductor. Dan also hears it and got on my case for having the sound a little too full the last visit up. Changing the inductance just slightly is at the crossover intersection, where phase matching, additions and subtractions occur, thus extremely touchy.
I agree with you, connections, all make a difference and need to be periodically checked. That is one area of concern with maximum attention.
The 1db you mention is spl, across the audio band "volume". What I mean is change in frequency response, or tonal balance change. The ear is incredibly sensitive to tonal balance changes.
That is why +/- 0,1db means so little and why one perceives different manufacturers sounding different even with a
+/- 0,1db spec from 20hz to 20khz. That change in tonal balance is only in the area of -54db down. That variance alters many natural harmonics that an instrument/voice produces, and is easily perceivable.
Changing the number of speaker wires in parallel alters both the total gauge, thus damping of the bass and the inductance at higher frequencies, altering the highs. Both parameters alter any masking effects, rise time (attack times), cleanness of the sound, sound stage, transparency etc.
Also remember this is a lab setting, my preamplifier, amplifier, speakers, ics have been designed and special listening tested to be accurate in absolute terms, so masking is virtually eliminated.
I hope this helps in clarifying and foggy explanations I may have written Scott.
« Last Edit: May 25, 2021, 06:04:23 PM by steve »
« Reply #7 on: May 25, 2021, 06:07:16 PM »
Just compared the Denafrips and will stick with my highly upgraded Modi 2. Just more natural; the -3db at 20hz did
not help the Denafrips.
« Reply #8 on: May 25, 2021, 11:04:58 PM »
I was curious about other dacs, especially the Denafrips. Do you recall which model?
« Last Edit: May 25, 2021, 11:07:07 PM by Nick B »
« Reply #9 on: May 26, 2021, 09:55:28 AM »
Hi Nick,
Yes, the Aries 2, the least expensive model.
But I noticed an interesting feature. If one inspects all the R2R series, except for Terminator and Terminator Plus DACs, the rest have a spec of -3db at 20hz. The Terminator and Plus have a spec of -0,2db at 20hz.
Listening, I found the deep bass was nearly as loud as from my Upgraded Modi 2, which is within 0,1db. Such an aberration between spec and sound is disconcerting to say the least. However, there is  more.
The Aries 2 definitely had a thinner/leaner lower midrange and mids. It was not bad, and even sounded quite refined. But it was enough to lose the "live", natural sound, especially when compared to my upgraded Modi 2.
The cause could be the use of a really poor capacitor in the analog circuitry, such as a power supply capacitor or coupling capacitor. I remember my old sony TC 350 reel to reel that used electrolytic caps as coupling capacitors. However, I tend to feel the electrolytic cap is more likely in the power supply. Tube amps are noted for fat bass somewhat due to electrolytic capacitors.
If the FR spec is good and the sound is great, that is excellent.
If the FR spec is good but the sound is bad, something is wrong.
If the spec is bad, but the sound is good, then something is wrong.
Gotta go.
« Last Edit: May 26, 2021, 02:30:03 PM by steve »
« Reply #10 on: May 26, 2021, 12:24:08 PM »
Hi Nick,
However, the Aries 2 definitely had a thinner/leaner lower midrange and mids. It was not bad, and even sounded quite refined. But it was enough to lose the "live", natural sound, especially when compared to my upgraded Modi 2.
The cause could be the use of a really poor capacitor in the analog circuitry, such as a power supply capacitor or coupling capacitor. I remember my old sony TC 350 reel to reel that used electrolytic caps as coupling capacitors. However, I tend to feel the electrolytic cap is more likely in the power supply. Tube amps are noted for fat bass due to electrolytic capacitors.
Gotta go.
Thanks, Steve. Quite interesting  :thumb:
« Reply #11 on: May 26, 2021, 02:36:44 PM »
Hi Nick,
Gotta go.
Your welcome Nick. It is definitely leaner than your stock Border Patrol DAC and even more so with the Jupiter cap upgrade.
It worked for audiophile Dan/Susan since he is using either Rogers LS 3/5A or Harbeth speakers in his primary system, I forget which one, and the other in his secondary system. But one has a little bumped upper bass, so the Aries 2 compensates his system.
Cheers
« Last Edit: May 31, 2021, 02:21:48 PM by steve »
« Reply #12 on: May 26, 2021, 11:57:01 PM »
Hi Nick,
Gotta go.
It worked for audiophile Dan/Susan since he is using either LS 3/5A or Harbeth speakers in his primary system, I forget which one, and the other in his secondary system. But one has a little bumped upper bass, so the Aries 2 compensates his system.
Cheers
Lean is not a good thing… 👎 I understand about using cables and gear to try and compensate for various system deficiencies, but conceptually, I’m quite against it. I use a full loom of Audio Envy cables and sometimes wonder if I shouldn’t at least experiment with another digital cable, but this hobby can get very time consuming and a bit spendy. Plus, I still need to finish speaker placement etc. But a couple of other projects have priority.
« Reply #13 on: May 27, 2021, 11:07:29 AM »
Hi Nick,
Gotta go.
Cheers
Speaker placement can be frustrating, but well worth it. Good luck with your endeavors Nick.
