Author Topic: Active Grounding  (Read 14633 times)
Active Grounding
« on: April 23, 2021, 11:41:51 AM »
  Seems to be a popular new grounding scheme. Any thoughts. Dave can you design one for reasonable money ? Nordost and Synergystic Rearch offer them at big money.
Re: Active Grounding
« Reply #1 on: April 23, 2021, 11:48:42 PM »
I've been working on one for a year.
There are two different approaches to this.  One is the stand alone ground noise sink that attaches to component's grounds via the RCAs and unused XLR connectors.  The other is the device that is connected to AC ground and is an attempt to sink noise to the AC ground at the power entry.  I think the latter is a poor choice.  What we are wanting is to drain ground plane component generated noise from the gear, not AC noise.
I'm a month off on this... Stay tuned.
I'm still trying to fill my Digi II orders.  One of the major components is unavailable nationally until July.  I am waiting for parts from Germany right now.  It sucks to develop a really good product and then have essential components go away... 🤬
« Reply #2 on: May 28, 2021, 09:45:23 AM »
I experimented putting a Copper ground bar in a box with soil. Attached wires to ground bar and then to unused RCA. HOLY NOISE REDUCTION BATMAN !!!. Moistened Soil then after 24 hours even quieter. Hurry up Dave.
I have a huge project that is coming to an end next week.  More, then!
Busy, busy, busy me  :thumb:
Offline Folsom
« Reply #3 on: May 28, 2021, 12:05:53 PM »
So... you water your Antenna?  :rofl:
« Reply #4 on: February 22, 2022, 02:07:33 PM »
  Of course don't you ? kidding aside. I was told to keep the ground rod for my electrical system in a moist atmosphere for better grounding. Applied same conditions to my experiment.
  Hint of the day:  dissolve as much epsom salts as possibe into a gallon or so of water.  Pour it around the ground rod and let it soak in.  Even better, make some holes around the ground rod.  I use a piece of #4 rebar 18" long, but anyting will do to make the holes.  Pour about a pint in and let it soak in.  Repeat daily until the epsom salts water is gone.  Repeat this about once a year.  It greatly enhances the earth ground local conductivity.  Easy and VERY effective at keeping the ground stabilty ongoing.
« Last Edit: March 09, 2022, 05:00:34 PM by P.I. »
Offline Hibernian
  • Newbie
« Reply #5 on: February 24, 2022, 06:38:02 AM »
Hi folks. Am having a hard time 'seeing' these ground-in-a-box' solutions, any pictures? Am imagining this might be a way to use fake plants to serve as grounding devices and a little room adjustment/decoration too.
