Author Topic: Recommend a Soldering Iron Under 75 Bucks  (Read 5263 times)
Offline James Edward
« on: April 02, 2021, 04:22:02 PM »
I NEED to start soldering again. It’s been 40 years- solder has changed, I haven’t a clue. I’d like a straightforward piece that works well. No bells and whistles- suggestions appreciated. I saw one that was recommended on ASR, but it was a ‘hold for two seconds, release, then press the up button to change temp, etc., etc.’. I want something that holds a temp and maybe? has simple adjustments for the new world of lead-free solder. Thanks.
I’d like to attempt an amp kit at some time in the future, so I figure practice might make some sense...
Esoteric K-07X
Re: Recommend a Soldering Iron Under 75 Bucks
« Reply #1 on: April 02, 2021, 06:19:13 PM »
« Reply #2 on: April 03, 2021, 05:45:48 AM »
Aisle 22 Bay 10- on my way! Thanks Pete.
Esoteric K-07X
« Reply #3 on: April 03, 2021, 10:34:34 AM »
Good solid unit. I have same one and it has worked like a champ for over 30 years.
This one works great & is a quality item...
https://www.homedepot.com/p/Weller-5-Watt-to-40-Watt-Soldering-Station-WLC100/100130478?source=shoppingads&locale=en-US
Go sling some solder!
Pete
« Reply #4 on: April 03, 2021, 02:33:21 PM »
I’m starting with the easy things first. I just practice soldered ~ 20 pieces of solid core wire from some Cat6 cable that I twisted together. I imagine stranded wire is much more difficult- heating it to melt the solder has to have a delicate/deft touch for sure.
Esoteric K-07X
« Reply #5 on: April 03, 2021, 03:16:39 PM »
The key is you have heat the to the point that the wire itself is melting the solder, not the iron directly.
With thin gauge wire it can be a very fine line between getting the wire hot enough to avoid a cold solder joint and getting it too hot and damaging the insulation.
Like everything else, it gets easier with practice
Offline malloy
« Reply #6 on: April 03, 2021, 10:53:48 PM »
Pete
I have the exact same unit bought from Fry's (seems so long ago). I've only had to buy a smaller tip for smaller, more precise jobs. Very reliable.
Paul
« Reply #7 on: April 04, 2021, 08:33:31 AM »
Pete
Paul
Paul,
I had forgotten all about Fry’s. A good place for “stuff” in the days when I was in Los Angeles...nearly 20 years ago now
Offline malloy
« Reply #8 on: April 04, 2021, 09:39:39 PM »
Paul,
The local Fry's was where I bought the Andrew Jones Pioneer bookshelf that I have as a backup speaker. Very sad to see brick and mortar stores go.
Paul
Offline Response Audio
    • Response Audio
« Reply #9 on: April 06, 2021, 08:29:09 AM »
There are a lot of good soldering irons/stations out there. My only advice is to get a unit with good reviews and affordable replacement tips. I have several very good soldering stations, desoldering stations, SMD station and several irons. Since i solder every day and irons are on 5-6 hours at a time, it can burn out irons quickly. For this reason I buy cheap irons from Parts Express.  They last me about 8 months to a year. I would rather burn up a $10 iron every year or so than burn out a $100 station.
Design Engineer
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
« Reply #10 on: April 06, 2021, 08:51:06 AM »
That’s a lot of soldering.... I was just on the Parts Express website, so which one do you use?
« Reply #11 on: April 06, 2021, 01:38:09 PM »
Still using my '70s era Weller soldering irons that are 7 watts and 40watts and going strong.  Here is the latest line:
https://www.weller-tools.com/consumer/USA/us/Weller+Consumer/Soldering+Irons
I also have a Tech temperature controlled soldering station I bought from Radio Shack decades ago and still working well.
Still using Radio Shack Eutectic 2% solder for my work.  The new EU style no lead solder does not work well even with silver content for me.
Good luck with your decision.
« Reply #12 on: April 06, 2021, 03:35:03 PM »
True confessions- I made some speakers back when I was 12-14, and dinosaurs roamed the earth. No one ever taught me, YouTube didn’t exist, and I winged it. Boy was I wrong. I was basically just melting and dripping the solder in place. Cold solder joint anyone? I even picked up some lingo! Fast forward to today- I’m using the Weller and just practicing, with much better results if memory serves... I appreciate the input, and maybe a kit is in my future...
Jim
Esoteric K-07X
