Author Topic: Rollo, Pete...  (Read 10004 times)
Re: Rollo, Pete...
« Reply #45 on: February 15, 2021, 11:02:25 PM »
Dave,
You’ve posted a pic and given it’s dimensions, but I’m still having trouble visualizing it. Are there any more pics available or pics of an original model?
Re: Rollo, Pete...
« Reply #46 on: February 16, 2021, 01:35:27 PM »
Oops, my bad.
It looks like a MiniBUSS.  I use the same enclosure.  It looks like this:
I really need new pictures.  All of my black boxes now have black cover plates. , Also, this picture shos the old receptacles.  The new receptacles are Pass & Seymour 5362ABK (black).
« Last Edit: February 16, 2021, 05:40:58 PM by P.I. »
Re: Rollo, Pete...
« Reply #47 on: February 16, 2021, 03:29:32 PM »
Oops, my bad.
It looks like a MiniBUSS.  I use the same enclosure.  Iy looks like this:
Thanks, Dave  :thumb:
Re: Rollo, Pete...
« Reply #48 on: February 18, 2021, 01:15:50 PM »
   Good call Dave. Still getting better after 250 hours. The imaging is top notch. Toes are a tapping.
Re: Rollo, Pete...
« Reply #49 on: February 18, 2021, 09:15:31 PM »
Thanks, Charles.  I'm very happy with it.
Check your email  :thumb:
Re: Rollo, Pete...
« Reply #50 on: February 26, 2021, 09:59:45 AM »
      OK . After 350 hours no more changing. All done. Plugged directly into dedicated 15A line using TWL HO PC PRAT, Bass, sound stage, imaging especially, slam all there and better than before. Adding an Uberbuss using another TWL HO PC was the end all. Everything I just described in SPADES. I have tried other PCs including Audio Envy  and Swiss Cable Ref+. Both VG however with Digi/Uber combo just different.  TWL HO is King with Digi/Uber combo. In my system anyway.
   Still messing around using a different power conditioner a Gigawatt PC2SE with DC blocker [ 8K ]. Pretty darn good as well. The bargin of the day is Digi/Uber combo.
Re: Rollo, Pete...
« Reply #51 on: February 26, 2021, 11:14:54 AM »
Very helpful that you are listing the various combinations you are trying. What is the TWL HO? Is it the Obsession? Was just on Pete’s site, but nothing listed specifically like HO
Re: Rollo, Pete...
« Reply #52 on: February 26, 2021, 12:17:40 PM »
I think Charles is referring to this... https://triodewirelabs.com/product/high-power-digital-american/
Re: Rollo, Pete...
« Reply #53 on: February 26, 2021, 12:44:03 PM »
Yes Was not sure if HC or HO was the right model. That is the one. Excellent choice.
Re: Rollo, Pete...
« Reply #54 on: February 26, 2021, 01:36:02 PM »
Ok, thx guys. Pete, what’s the difference between the HC vs the Obsession?
Re: Rollo, Pete...
« Reply #55 on: February 27, 2021, 07:31:46 AM »
Hey Nick,
The "Obsession NCF" is an all out assault, starting with the crazy expensive Furutech FI-50 NCF series of connectors ($385 EACH!)... http://www.furutech.com/2015/11/18/12059/
The "Obsession NCF" utilizes conductive silver mylar as well as patented conductive carbonized external sleeving to assist in maintaining clean signals as well as providing interference & RF filtering. It is my "beefiest" power cord with 20% overall larger diameter conductors than the "High Power Digital American”.
The "High Power Digital American" (HPDA) uses super high quality IeGO connectors, made with Japanese Furukawa pure copper, mated to my custom, CNC-machined aluminum with carbon fiber outer "Lightning" connector bodies. The HPDA uses all the "trickle-down" technology learned in the "Obsession NCF", including conductive gold mylar as well as patented conductive carbonized external sleeving to assist in maintaining clean signals as well... It is no slouch of a cord...
If you have further questions, let me know.
Best regards,
Pete
Re: Rollo, Pete...
« Reply #56 on: February 27, 2021, 10:14:54 AM »
Hey Nick,
Best regards,
Pete
Thanks for the detailed explanation, Pete. Amazing quality materials and R and D.
