Author Topic: Volume pots  (Read 792 times)
Volume pots
« on: October 01, 2020, 12:06:19 PM »
  Looking for the quietest one made. There are variable resistor types and stepped as well as Autoformers. The use will be for an amp.
Lamm Industries - Aqua Acoustic, Formula & La Scala DAC- INNUOS  - Rethm - Kuzma - QLN - Audio Hungary Qualiton - Fritz speakers -Gigawatt -Vinnie Rossi,TWL, Mad Scientist, Swiss Cables
Re: Volume pots
« Reply #1 on: October 01, 2020, 08:38:24 PM »
I'm not sure I understand what you mean by quiet. As a passive device a volume pot should not make any noise at all, except when you are moving it. And I am not sure why having the pot make a little noise while you are moving it would be a big deal. It's not like you would be doing any critical listening during the second or two it takes to make a volume change.  What am I missing?
• VPI HW-19 Mk IV/SDS/SME IV/Benz Micro Glider
• Pro-Ject Pre Box S2 DAC/Rasp Pi Roon Endpoint/Denon 2910
• DigiBuss/TWL PC&USB/MIT Cable
Re: Volume pots
« Reply #2 on: October 01, 2020, 11:28:47 PM »
Resistive elements have a parameter that is called the “temperature coefficient of resistance”. It is quantified in parts per million (ppm).  These numbers can run any where from 0.01 to over 1200 with lower being better.  Most commercial pots run in the 750 - 1000 range.  This directly correlates to “self noise” generated in the resistive element.  At very low voltages, where TCR noise is most prevalent,  this can be a big deal.  Take a low output moving coil and we are talking about possible serious consequences.
So here is my take:
VHQ stepped attenuators can utilize resistors like the bulk foil one made by this company-
http://www.texascomponents.com/store/VishayFoilResistors.asp
They are a great company and make and quickly ship small order products.  Using all TCC resistors in a stepped attenuators can get very, very, VERY expensive.  I once built a 47 step, stereo attenuator for a customer and the cost for resistors alone was over $1500.00.  Made me nervous during the build due to the 380+ solder joints with an extremely difficult to work solder.  Done with that!
There are some great attenuators available here:
https://www.hificollective.co.uk/attenuator/glasshouse-elma-a47-jumbo-stepped-attenuator-mono.html
When it comes to pots I am a fan of the plastic element TKD products:
https://www.partsconnexion.com/tkd-potentiomters.html
They ‘sound’ very good which is to say they don’t sound at all.
DACT is another great option.  This is the best “bang” I know of:
https://www.ebay.com/itm/283538214885
I’m not a fan of Alps. I had too many fail in studio applications.  They are, however, a good source for motorized pots.
For autoformers, Dave Slagle is THE Man! :  http://www.intactaudio.com/atten.html
There are so many options.  Pick a price point and do a search.
« Last Edit: October 02, 2020, 11:36:39 AM by P.I. »
Offline Folsom
Re: Volume pots
« Reply #3 on: October 02, 2020, 06:15:08 AM »
The eBay DACTs are crazy good for the money. I'm not hesitant to use one at any price point except the fact that it has a limited number of positions.
Re: Volume pots
« Reply #4 on: October 02, 2020, 09:35:05 AM »
  Was leaning towards the TDK plastic. Good reviews. Thanks Guys.
Offline Response Audio
    • Response Audio/Musica Bella Audio
Re: Volume pots
« Reply #5 on: October 07, 2020, 10:07:53 AM »
Hey Charles. Just curious why you are installing a volume control in or prior to an amplifier?
Design Engineer
Raven Audio
Purity Audio
Musica Bella
www.RavenAudio.com
www.ResponseAudioNY.com
Re: Volume pots
« Reply #6 on: October 07, 2020, 10:40:53 AM »
  The Alan Eaton design uses one. I really would prefer my preamp. I am experimenting either by bypassing gain control and using preamp OR using a better gain control without preamp.
Re: Volume pots
« Reply #7 on: October 13, 2020, 09:24:47 AM »
  OK bypassed the volume pot and put Lamm Ref Preamp back in. No contest. More body, slam and bigger stage. I appreciate the K.I.S.S. theory simpler not as good. So enamored with the 45 tube now considering a Tektron mono blocks.
