Author Topic: Anyone here running the Geek Pulse X DAC with the LPS  (Read 1957 times)
Offline Response Audio
    • Response Audio
« on: September 05, 2020, 11:45:38 AM »
I just obtained a new Geek Pulse X with LPS. If I power it with the LPS, I get no sound out of the DAC. The DAC does power up but no sound output. I am running SPDIF from the digital out of a CD player and analog outputs to my 2A3 preamp.
If I take the LPS out of the equation and just use the wallmart to the DAC. The DAC works fine.
I'm stumped....
Design Engineer
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
Re: Anyone here running the Geek Pulse X DAC with the LPS
« Reply #1 on: September 05, 2020, 01:31:32 PM »
  If you are stumped we are. :-P Kidding aside . A grounding issue. I had similar issue just with a different DAC. Had to ground LPS.
    • Response Audio
« Reply #2 on: September 09, 2020, 06:20:14 AM »
Found the problem. As it turns out,  the power strip/filter I had it plugged into wasn't working for it. Plugged the power supply into the wall and all is fine  :duh
Design Engineer
Response Audio NY
« Reply #3 on: September 09, 2020, 03:41:23 PM »
That would do it......
