Author Topic: Cartridge Budget  (Read 312 times)
Cartridge Budget
« on: August 10, 2020, 10:22:40 AM »
There are guides out there that provide recommended budgets for cables as a percentage of your total system cost. My question is: Is there a  guideline for cartridge budget as a percentage of turntable cost? For example I own a VPI Classic 2 (original arm). What should my budget be for a cartridge?
Modwright LS100 Pre, Art Audio Vinyl Reference, Wells Audio Inamorata Pwr, VPI Classic II/Dynavector 20X2L, Two plus Two Speakers,  Roon Rock, Auralic Vega DAC, Emotiva ERC-3, MIT, WireWorld, Wywires, Shunyata, TWL
Offline Folsom
Re: Cartridge Budget
« Reply #1 on: August 10, 2020, 11:02:50 AM »
Try an Audio-Technica AT-VM95C. (if the stylus wiggles put a little clay or something is the corners of it, wipe off excess when you put it back on)
No joke. Ignore everything you read and think you know, just give one a listen.
« Last Edit: August 10, 2020, 11:05:00 AM by Folsom »
« Reply #2 on: August 10, 2020, 11:31:48 AM »
I've heard lower end Grado sound good, but overall I think you have to spend a few bucks to get better performance from a cartridge.  There are some nice sounding options starting around $400... all according to my ears.
“In the end, we will remember not the words of our enemies but the silence of our friends.” Dr. Martin Luther King, Jr.
« Reply #3 on: August 10, 2020, 11:37:39 AM »
OK so it sounds like I am good. I have a Dynavector 20X2L ($1200) so it sounds like I budgeted enough.
« Reply #4 on: August 11, 2020, 01:54:23 PM »
    Better cartridges cost more money. If your TT spins at the correct speed and the arm can handle it then it is up to the owner what to spend. The budget thing IMHO is for conversation only.
Lamm Industries - Aqua Acoustic, Formula & La Scala DAC- INNUOS  - Rethm - Kuzma - QLN - Audio Hungary Qualiton - Fritz speakers -Gigawatt -Vinnie Rossi,TWL, Mad Scientist, Swiss Cables
