Author Topic: Reference Lab Quality SAS Audio Labs 11A Line Preamplifier  (Read 395 times)
    • Reference components
« on: August 08, 2020, 08:04:27 PM »
The last used SAS Audio Labs Reference 11A that was for sale was some
5 years ago, in Europe.
The 11A was the reference preamplifier by both Bound for Sound editor/publisher Martin DeWulf and by BFS reviewer Dr. Richard Weiner. (No magazine advertisements accepted.)
The only preamplifier on the planet that has an adjustment to compensate for different amplifier input impedances (Z) on the fly, which affects the frequency response.
Six power supply filter stages. Specialized filtering to prevent any input contamination from AC, power cords, transformers etc.
Only the highest quality parts were utilized, such as Vampire all copper jacks, Military Grade non-inductive resistors, 6N pure copper wire, gold plated tube sockets etc. Parts tolerances were less than 0.5% and between channels.
Mute section to prevent thumps with both power on and off
Series vacuum tube regulation
An AC polarity switch (mute will function when flipped, ~45 seconds)
The 11A under went 6 years of specialized, proprietary listening tests for perfect, natural, total accuracy of your music.
The owner's personal reviews.
"Dr. Rich Weiner: "The SAS 10A/11A is the most musically truthful preamp I'm aware of, and I will expand that statement by listing some of the line stages I've had in my otherwise very stable system: Herron VTSP-1, VAC CPA III, VAC Standard LE, Audio Research 3A, ARC 8, ARC 10, Mark Levinson ML-1, Levinson ML-7, Levinson ML-10A, Original Aronov PS-100 and Musical Concepts modification, Nagra PL-P, Beveridge RM-1, Rappaport, Placette Passive - there are more, but you get the point. Until I got the 10A/11A, I struggled to make the other components live up to their potential."
(Rich owns upgraded $15,000 300B monoblock amplifiers.)
"Graham: "I took the B11A into a shop in Auckland. I know the owner fairly well, and we agree that Shindo make some wonderful pieces of kit. (I wasn't looking for a change!) Almost immediately we started listening, he said "That's really fast!" We also agreed that the B11A was much clearer, making the Shindo sound slow, muddy, and coloured."
"Bob: "Hey guys. . .if anyone's interested, I'm selling my Tram 2 preamp since my SAS B11A is so awesome...." (Tram 2 uses 45, 2A3s)
Specifications are given for those interested in such.
Notice the FR specification is not simply +/-0,1db from 20-20khz. This equates to tonal variations in the poor range of -54db.
Clearly perceived.
Frequency Response 20hz:                  < -0,015db, 25k load. (16db tighter than 0,1db spec)
Frequency Response 20khz:                 < -0,0015db at 20khz, 100pf load (36db tighter than 0,1db spec)
Gain:                                                  20db
Total Harmonic Distortion at 2 vrms:      0.015%, Approximately -78db or less (Min 18db less than with any 6SN7 or variant)
Channel Separation at 10khz:                90db typical
Signal Polarity:                                     Inverts
Input Impedance:                                 25k ohms
Output Impedance:                               1.9K (1900) ohms
Min. Amplifier Input Impedance:             25k ohms (20k ohms but with slight loss of bass)
Volume Controls:                                  2
Tape Loops, HT bypass:                         Optional
Line Inputs:                                           3 Basic Version (5 Standard version)
Preamp. Outputs:                                   2
Line Cord Length:                                  6 feet standard
Power Consumption:                              28 watts
Power Requirements:                             120/240 Volts AC, 50/60hz (set for 120 volts, 0,25 amp slo-blo)
Dimensions:                                          19" front
                                                            4" high (with stock feet)
                                                            14 1/4" deep (counting knobs and jacks)
Condition good, gold knobs are little dingy from hands.
Contact me vis PM or stevesammet at omnilec.com
Cheers
« Last Edit: August 11, 2020, 10:02:56 PM by steve »
Steve Sammet (retired, owner, SAS Audio Labs)
"V" Very Low Capacitance ICs, 40pf 1 meter
SAS Audio Labs Test Phono Stage
SAS Audio 11A Tube Reference Preamplifier
SAS Audio Labs 25 W Triode Reference Monoblocks
2 way test Spkrs, 28 - 20khz  -3db (28hz)
  • Global Moderator
Re: SAS Audio Labs 11A Line Preamplifier
« Reply #1 on: August 08, 2020, 08:54:22 PM »
It’s the first one I’ve seen for sale, Steve. Have maybe seen 1 or 2 of the 10As. Good luck on the sale.
ICEpower 1200as2 amp
Audio Hungary APR 204 preamp
Fritz Carrera 7 BE speakers
Auralic Aries Mini & Mojo Audio lps
Audio Envy cables
« Reply #2 on: August 09, 2020, 06:31:34 PM »
Thanks. I also cannot remember when the last used 11A was sold. I made an adjustment in my above post by adding
some customer/BFS reviews.
By the way, did you notice the FR and Distortion specifications in my spec section? The fr is not simply +/-0,1db 20-20khz,
which is an absolutely worthless spec. The distortion is about a tenth less than other vacuum tube preamplifiers. The sonic difference is perceptible.
When it is gone, one won't see it again.
Cheers and great week Nick.
« Last Edit: August 09, 2020, 06:59:02 PM by steve »
Re: Reference Lab Quality SAS Audio Labs 11A Line Preamplifier
« Reply #3 on: August 27, 2020, 10:41:52 AM »
Mrs. DeWulf just contacted me and has decided not to sell the 11A as it is the best of the preamplifiers
Marty kept on hand to compare against in his reviews.
Cheers
« Last Edit: August 27, 2020, 10:48:05 AM by steve »
  • Global Moderator
« Reply #4 on: August 27, 2020, 11:41:16 AM »
Well, Steve, it is staying in a good home. It was so nice meeting Marty at a CES years ago as I was such a long time subscriber to his newsletter.
Good luck with the remaining sales.
Audio Envy cables
« Reply #5 on: August 31, 2020, 11:00:35 PM »
Thanks Nick. I know what you mean. Marty was a nice guy who loved audio to the tenth degree. He loved to tinker and repair
components when he had a chance. He will be sorely missed.
Here is a new list from Mrs. DeWulf, with prices.
« Last Edit: August 31, 2020, 11:03:56 PM by steve »
