i did some on line searching; seems it's not all that unusual. could be a tube, but could also be a filter cap. which the general consensus is don't mess w/the caps yourself - lethal voltages there. you could check tubes by gently tapping them, and/or removing and replacing them. you could try swapping the l/r channel tubes. i'm assuming the noise is coming from the speaker...
doug s.
Recently the left ch 211 amp had slight and short whistling sound. Anyone know what would that be ? tube ?
