Author Topic: Turning bad situation into something positive.  (Read 24251 times)
Re: Turning bad situation into something positive.
« Reply #45 on: May 14, 2020, 05:43:40 AM »
Nice progress Jim!
How'd you like the sprayer, worth the investment?
Which one do you have?
« Reply #46 on: May 14, 2020, 08:15:29 AM »
Nice progress Jim!
I bought the Krause and Becker from Harbor Freight. In general I have had good results from their tools. This one was a bitch to prime first time. Also they don't tell you that they use a pressure gage (low pressure turn on motor, hi pressure cuts off motor) So when I was spraying I didnt understand why the motor was shutting down lol. It didnt take too long to figure that out.
I really wanted one to spray the outside of the house. but when i wanted to paint this I figured it would be a pita to do with a brush.
besides the financial investment (not much) there is a time investment to learn to use it correctly. Once you are off and running it is FAST! painting it took less than a half hour probably closer to 20 minutes.
« Reply #47 on: May 14, 2020, 08:56:28 AM »
Nice, 20 minutes is pretty darn quick for all that area, especially with all the nooks and surfaces!
I'm assuming you bought the $210 one not the $25(?)
« Reply #48 on: May 14, 2020, 10:06:28 AM »
ha ha yea $210. but I had a 20% coupon so i got it cheaper. And yes as my wife said 'I went at it like a Mad man'
Once it was working I wanted to make sure I got done. but now realized I didn't need to be concerned as it was working correctly.
Room Updates
« Reply #49 on: May 15, 2020, 04:20:50 PM »
first coat of paint and installed some lighting
« Reply #50 on: May 15, 2020, 08:57:04 PM »
You're doing this yourself?!?! Very impressive! Really looking good!
Took me months to do my room over, but I was going to work every day, so only working on the room on weekends and the occasional evening.
« Reply #51 on: May 16, 2020, 07:42:08 AM »
well, I am doing mine partially myself. I paid a contractor to do the structural and I had someone do the rocking. everything else Im doing. I work now but hope to retire soon. This project started in March and was stagnant for quite a few weeks as contractors were not coming out to work so the project was on hold. Today I am installing outlets, and maybe spray the old paneling in the other part of the basement. Fun, Fun Fun!
« Reply #52 on: May 16, 2020, 10:18:02 AM »
  Coming along Jim. Looking good.
« Reply #53 on: May 16, 2020, 10:21:24 PM »
Nobody should ever go to Harbor Freight without a coupon. I must get at least half a dozen in the mail  every month.  :thumb:
« Reply #54 on: May 24, 2020, 01:02:51 PM »
OK so although I am making progress it would not show up in pictures so I will wait until next week. TMAZZ assisted me with electrical and I have advanced the lighting circuits. I also worked of a suspended ceiling in another section of the room. Today I did some floor leveling. Getting ready for flooring then it starts really looking like progress.
« Reply #55 on: May 25, 2020, 06:42:58 PM »
Glad things are moving along, was starting to wonder what was happening ;)
« Reply #56 on: May 25, 2020, 09:14:42 PM »
Good progress, Jim, and nice of TMazz to assist. Maybe you can convince him to do more....like comparing it to the joy of whitewashing Aunt Polly’s fence...Just a thought :)
floor is in!
« Reply #57 on: June 04, 2020, 10:11:20 AM »
Installed Coretec LVP! Looks OK but I don't like the sound, kind of like, clop, clop.
Last night I did a lot of trim work that is not shown in the pics. I'll post that later. Tomorrow is move in day. But there is still quite a bit more work to be done. ethernet lines etc. accent lighting...
« Reply #58 on: June 04, 2020, 12:36:08 PM »
Lookin' good  :thumb:
moving in
« Reply #59 on: June 06, 2020, 04:09:42 PM »
movers came yesterday and this mornings job was to start unboxing and also to throw out lots of stuff I no longer need.
