Author Topic: Turning bad situation into something positive.  (Read 24260 times)
room rocked
« Reply #15 on: May 06, 2020, 02:51:39 PM »
room rocked
more pics
« Reply #16 on: May 06, 2020, 03:02:47 PM »
what a pain to resize pics :rofl:
main listening area is 13' 6" x 22
ceiling is lower than 8 ft didnt measure but maybe 7' 2 "??? Just guessing
« Last Edit: May 06, 2020, 03:04:34 PM by jimbones »
Re: Turning bad situation into something positive.
« Reply #17 on: May 07, 2020, 10:17:55 AM »
  Looking good.Did you remove  lolly columns with a new beam ? Sub panel ? Clg ? Flooring ? Be advised to use a reflective surface to a non reflective surface. Carpet floor sheetrock clg. Acoustic tile wood floor as an example.
« Reply #18 on: May 07, 2020, 10:18:51 AM »
  Almost party time.
« Reply #19 on: May 07, 2020, 11:42:01 AM »
Yes I removed the column and installed a new beam. It was a custom product and cost a bundle. have 3 dedicated 20 Amp lines. I am  installing waterproof flooring. The walls are 5/8 moisture resistant. The ceiling is going to be a wood slat I'll find a photo in pintrest and post.
« Reply #20 on: May 07, 2020, 11:46:26 AM »
  Almost party time.
Interesting that once I will finally have the space be able to host meetings,  we have these social distancing things to observe. I think this is fairly important since we are in that age group where we are most vulnerable. (Male over 50) I think mini meetings are still the plan until we could relax a bit.
« Reply #21 on: May 07, 2020, 01:53:30 PM »
  Almost party time.
   I will wear my Scuba gear, all will be good in time.
« Reply #22 on: May 08, 2020, 06:02:45 AM »
Lots of good work Jim. Keep on "rockin"  :rofl:
« Reply #23 on: May 08, 2020, 01:50:31 PM »
Coming along nicely Jim!
ceiling sample picture
« Reply #24 on: May 08, 2020, 02:26:47 PM »
So this is an example photo of something I would like to do
« Reply #25 on: May 08, 2020, 03:53:41 PM »
Something to think about Jim. That may not work as well, look as good, in a basement. That's probably a 9 or 10 foot ceiling, and that may feel rather confining when much closer to your head, and it will eat into what's already less than standard ceiling height.
« Reply #26 on: May 08, 2020, 05:14:05 PM »
Recommendations on ceiling alternatives
« Reply #27 on: May 08, 2020, 05:51:43 PM »
Smooth sheet-rock(?) Mine is putty knife stuccoed, because that's what it was when we moved in, and I just repainted.
Had I gone down to studs in the whole room, instead of just a few patches, I would have gone for smooth.
« Reply #28 on: May 09, 2020, 04:18:13 AM »
Barry I actually GAIN height. The old ceiling was furring strips with metal track with ceiling tiles. This will be a single piece of 5/8 wood strip attached directly to joists.
« Reply #29 on: May 09, 2020, 12:38:27 PM »
 I would tend to agree with Barry. Using SR with proper surface [ paint, stucco, acoust. tile ] allows you to control reflections, absorbtion and all that stuff.
