Author Topic: can some damaged tubes be revitalized  (Read 1178 times)
« on: March 30, 2020, 07:25:51 PM »
Saw this on YouTube. I wasn’t aware this was possible. Comments, pls
https://www.youtube.com/watch?v=Uv0D1-2cVg0
Orchard Audio Starkrimson Ultra amp
JM Reynaud Voce Grande speakers
iFi Zen Stream & Mojo Audio lps
Wywires Silver cables & Audio Envy power cords
Re: can some damaged tubes be revitalized
« Reply #1 on: March 31, 2020, 07:05:14 AM »
Yes Nick it is possible for Thoriated Tungsten cathodes, depending upon how much thorium is left in the interior cathode tungsten filament. IF I remember correctly, with no plate voltage, run the filament 20% above normal for a few minutes. Repeat as necessary. The thorium will "boil" to the surface and emission will increase, if there is thorium left.
The only oxide cathodes I have ever seen improve is in picture tubes. There are usually several stages of a picture tube rejuvenator one can try. The highest stage actually causes sparks inside the tube, ripping off the outer layer of oxide material from the cathode so fresh material is now on the surface. Sometimes it works, sometimes it ripped off all the material, or what was left.
Steve Sammet (Owner, Designer, Electron Eng, SAS Audio Labs, Ret)
Accutex 320 iii STR Mov Iron Cart
