Author Topic: Look out Scan Speak, SEAS, SBA, etc! Here comes Purifi  (Read 3486 times)
Offline mresseguie
« on: January 13, 2020, 08:38:05 AM »
Have you heard about this company? Have you read about their new midwoofer? Here are some tidbits:
PTT6.5W04-01A 6.5" midwoofer
https://purifi-audio.com/transducers/
https://purifi-audio.com/tech/
https://audiophilestyle.com/ca/reviews/purifi-ptt65-woofer-and-1et400a-amplifier-technology-review-r866/
I spent over an hour reading up on this driver, and I must say I'm excited.  :yay2: I have found myself thinking I ought to contact someone about creating a two-way speaker with this midwoofer.
I do need another speaker, right guys? I'm sure of it. Help me out here.  :thumb:
Don Sachs Model 2 preamp
Hapa loom
Re: Look out Scan Speak, SEAS, SBA, etc! Here comes Purifi
« Reply #1 on: January 13, 2020, 09:58:20 AM »
 Very interesting. Sounds like fun. -3db at 32 HZ in room is VG for its size.
« Last Edit: January 13, 2020, 10:04:04 AM by rollo »
« Reply #2 on: January 13, 2020, 10:46:39 AM »
Yes, I’m sure you do  8) Was curious about the pricing and it’s about $350
The first guy to contact is probably Fritz
Offline Folsom
« Reply #3 on: January 13, 2020, 01:02:35 PM »
They do look pretty amazing.
Offline Folsom
« Reply #4 on: January 13, 2020, 04:48:22 PM »
So just order a set of Fritz speakers using them? Maybe?
Offline AJ Soundfield
    • Soundfield Audio
« Reply #5 on: January 15, 2020, 06:03:16 AM »
The Purifi is a nice driver for sure.
...but I see no audible advantage over the Dan Wiggins designed 7" Anarchy, which actually has slightly more clean stroke LF output capability.
Where the Purifi excels is measured mid band distortion...at levels uncorrelated to either audibility...or preference.
Looks great "on paper" though. For many, that's enough.
cheers,
AJ
Loudspeaker Manufacturer
    • Soundfield Audio
« Reply #6 on: January 16, 2020, 04:22:13 PM »
I should keep it secret since they keep selling out fast, but alas... :)
https://www.diysoundgroup.com/speaker-parts/speaker-components/woofers.html
    • Soundfield Audio
« Reply #7 on: January 17, 2020, 07:14:35 AM »
i can see why they sell out, at those prices.  i need to investigate tapped horn subs w/these.  there's a build flat to 25hz w/one that i've seen, but flat to <20hz would be better.
thanks, aj!
doug s.
You're welcome Doug. I do recall some tapped horn subs using these, out there somewhere. But they are solid up to mid frequencies for 2 way use as well..with a competent XO of course.
