Author Topic: USB cable.  (Read 2207 times)
Offline Guy 13
  • Audio should be simple !
Grace Digital Mondo RIT
Cambridge Mini sub 2.1
Schiit Fulla 2 DAC
Schiit SYS PCC
Lot more stuff on storage
Re: USB cable.
« Reply #1 on: December 13, 2019, 07:12:54 AM »
Thats not a USB cable
Re: USB cable.
« Reply #2 on: December 13, 2019, 07:17:40 AM »
  What is it then ?
Re: USB cable.
« Reply #3 on: December 13, 2019, 07:34:29 AM »
Thunderbolt, it was developed by Apple
Re: USB cable.
« Reply #4 on: December 13, 2019, 12:07:35 PM »
It is also compatible with USB 3.1 spec according to the text.  Looks like a USB C connector.
Re: USB cable.
« Reply #5 on: December 13, 2019, 02:10:35 PM »
If its Apple it is usually proprietary. You could use an adapter.
Re: USB cable.
« Reply #6 on: December 13, 2019, 10:08:40 PM »
Everything you ever wanted to know about USB and Thunderbolt:
https://www.cnet.com/how-to/usb-type-c-thunderbolt-3-one-cable-to-connect-them-all/
Bottom line: although there are differences between the two standards a Thunderbolt 3 cable can be used to connect two USB 3 C ports.
