Author Topic: thinking about new amp and pre or integrated  (Read 14809 times)
« on: December 03, 2019, 04:10:43 PM »
As I’ve mentioned in another thread, I’m very happy with the new Fritz Carraras.
These “tiny tots” are mighty fine... I now have a more holographic presentation and it’s more fun to listen to. I’m getting very good sound nowadays using the ICE stereo power amp 1200as2 along with the Border Patrol SE nos dac and the somewhat quirky, but excellent sounding Audio Hungary APR 204 preamp. That beryllium tweeter retrieves detail beautifully and without harshness. It’s especially and surprisingly nice on older and somewhat poorly recorded material.
There are two issues, though, that I’d like to improve. One is some remaining harshness on vocals and some instruments that I think might be the ICE amp and the other is some boominess in the bass that is room related. Maybe they’re both room related. I’ve never, ever used room treatments, but I’m trying to learn as much as I can. I’ve previously mentioned here that I sent Dave...Mr Uber  :thumb: and Greg Rael who does the PI Audio room treatments, some pics of my room. They both expressed their sadness as to my room parameters and choice of speaker placement 😢 Doug s also has looked at the room pics and offered a suggestion.
So there are a few ways to proceed. One is to try another amp, or even an integrated, and see if I can get rid of that bit of harshness. Very likely it would be tube or at least a solid state that has a reputation for a tubelike presentation. As I live alone nowadays, I could dramatically change speaker placement so they would fire into the horizontal or short side of the room layout rather than the long side of the room. By changing to the short side/horizontal placement, both Fritzes would not have a close boundary wall on either side. So altering the placement is doable, but not preferable.
Based on some research on my part and some helpful suggestions from members here, there are a few companies that quite interest me as to amps, preamps and integrateds.  Those would be Audio Hungary, Microzotl, Don Sachs and NAT. I’ve also had a couple of offers to send me amps for evaluation which I very much appreciate.
So I’m open to suggestions on equipment and any other thoughts you may have.
By the way, room dimensions are about
17’W x 26’L x 11’H open floor plan room
« Last Edit: December 03, 2019, 04:16:19 PM by Nick B »
Offline Guy 13
  • Audio should be simple !
« Reply #1 on: December 03, 2019, 06:19:35 PM »
Hi,
that's quite a large room you have.
Just saying.
My dedicated listening room is :
15' wide X 23' long and 9.5' high.
Guy 13
Grace Digital Mondo RIT
Cambridge Mini sub 2.1
Schiit Fulla 2 DAC
Schiit SYS PCC
Lot more stuff on storage
Offline mresseguie
Re: thinking about new amp and pre or integrated
« Reply #2 on: December 03, 2019, 07:09:08 PM »
Nick,
Call the folks at GIK Acoustics and supply them some information about your listening room. I'll bet they can suggest some treatment that will be considerably less expensive than trying different amplifiers. [Make sure you buy the diffusor from Greg and Dave.]
Michael
P.S. We will fly directly from ATL to Taiwan this Sunday, so my offer will have to wait until next April. Start lifting weights.  :thumb:
Don Sachs Model 2 preamp
Hapa loom
Offline Folsom
« Reply #3 on: December 03, 2019, 07:13:42 PM »
Well Nick the number one thing I still suggest is trying that little tiny amp just to diagnose where you're woes come from. It can rule out the amp or preamp.
What metallurgy are your cables? Can you talk about them? Do you have enough regular IEC cables that aren't audiophile ones to swap in and check?
Are you more about 3D sound, holographic type sound, soundstage, or more about timbre, dynamics, resolution?
IME I've never heard a stereo that sounded fatiguing or bad due to the room. The room can be changes to improve a stereo, as well know, but it won't radically remake a stereo.
« Reply #4 on: December 03, 2019, 09:06:59 PM »
Hi,
Just saying.
Guy 13
Yes, Guy. A bit bigger than I’d like, but the other rooms are quite small. It has worked for me since 2003 🎶🎶
« Reply #5 on: December 03, 2019, 09:14:01 PM »
Nick,
Michael
Michael,
Have a good trip! I am mentally lifting weights as I write this 😃🏋️  I’ll look into GIK and revisit this issue with PI. My hunch is it’s room acoustics and the amp... As to that Kootenay, I’m sure it would sound great, but am quite concerned about the weight. The Audio Hungary APX 200 amp weighs mid 60s or more. Ugh
« Reply #6 on: December 03, 2019, 09:49:42 PM »
Jeremy,
Your amp idea is good..and cheap. The amp you linked this time is different than the first one which I prefer. I’ve saved that link somewhere.
All cabling is copper and diy that a friend did for me. No ofc or occ stuff. Very, very thin gauge copper on the digital and ic’s all using rca’s. The power cords are mostly thick gauge solid copper and the speaker cable braided copper. Nothing is shielded. It’s probably very good, but I’d like to compare it to a couple of companies. I may have some inexpensive power cords somewhere, but I tend not to keep extra cables or equipment.
As to what type of musical presentation I prefer, it’s actually a combination of 3D holographic with timbre and resolution. What I’m getting now is certainly on the right track. The timbre is better now than anything I’ve experienced in 30+ years in this hobby. As to slam, I actually have more than I need or want. I’ve been startled more than a few times with the leading edge of transients. It’s certainly something I’m not used to and I don’t know if it’s an accurate portrayal or not.
As to your thoughts about amplification and listener fatigue due to room acoustics, I really don’t know. I’m sure you have much more experience than I do.
Offline Folsom
« Reply #7 on: December 04, 2019, 12:05:47 AM »
Well, they're all the same, the little amps, to me. They're all ok for a toy background system or computer, but have an universality of sounding very easy.
You can have 3D with timbre and resolution but it's hard to enhance 3D without destroying the other ones at some point. You might greatly prefer some tinned copper interconnects and speaker wire (you don't have to terminate them). I personally prefer it over basically everything but my own made stuff.
Your speakers can play well with surprisingly low amounts of power, so something like a fairly powerful SET isn't out of the question. But also a Firstwatt J2 might be an option.
I wish I could help more on the digital front end. I'm all TT because I haven't made a DAC yet.
« Reply #8 on: December 04, 2019, 12:30:03 AM »
Thanks for the links. The prices are right. I’m not sure what I’ll do about wires and in what sequence of trying things. You’re right about the Fritzes not needing much power. Fritz tells me he’s run them with as little as 8 watts. I’ve never had a SET amp and it sounds quite appealing. I believe that Firstwatt J2 is a Nelson Pass creation. $4,000 retail and sold usually for $2,000 per HiFi Shark.
May I suggest you start designing that dac. It would be great fun to hear your amps and dac.
Offline Folsom
« Reply #9 on: December 04, 2019, 12:50:41 AM »
I don't think I'd even start unless I had at least $10k min to put towards it. A DAC is a whole other thing... because I don't think they're even good, not really. It's a lot of work to unpack that mess.
Decware has some awfully pretty triode amps for not a ton of money. I was listening to the Qualition on YouTube, it's a nice sound if that's what you like. For me it's too airy, floaty, candy type sound.
Offline Guy 13
« Reply #10 on: December 04, 2019, 02:17:59 AM »
Hi,
I also think that the music in the video is :
'' ....is too airy, floaty, candy type sound. ''
I have the Decware SE84C+ but only 2wpc,
need at least 95db speakers.
Guy 13
Schiit Fulla 2 DAC
Schiit SYS PCC
« Reply #11 on: December 04, 2019, 06:56:27 AM »
  Nick. You are lucky. That room size is close to perfect. Change it all around. That will change the memory of before as well as drastically improving your presentation. Speaker position, toe in etc can affect HF.
  I would let the speakers get 350 hours on them first. Change the room layout. Do not rush this. Time is on your side.
« Reply #12 on: December 04, 2019, 09:36:34 AM »
I agree a bit about this Qualiton YouTube video. If I go the AH Qualiton route, it would be because of the tonality and nice midrange.
I took a look at Decware. Nicely done website and it appears well respected products.
« Reply #13 on: December 04, 2019, 10:33:06 AM »
Charles,
Am slowly putting the hours on them. Will try and post a couple of pics. Its interesting that we both enjoy the Fritzes and Audio Hungary. Would be fun to hear some of your other products. Maybe at one of the shows if I can get adventurous and afford it.
Offline Folsom
« Reply #14 on: December 04, 2019, 11:51:40 AM »
Nick you aren't near any shows! Hmm.
