Author Topic: CD Cleaner/ Polish?  (Read 1914 times)
Offline James Edward
CD Cleaner/ Polish?
« on: November 22, 2019, 04:04:42 AM »
Has anyone tried one of the cd cleaners/ enhancers on the market such as the Audience Auric Illuminator...
https://www.audioadvisor.com/prodinfo.asp?number=AUAURIC
Or the Walker Audio Ultra Vivid CD Enhancer...
https://walkeraudio.com/?product=ultra-vivid-disc-enhancer
Or one of the myriad others out on the market? If so, what were your impressions?
Esoteric K-07X
Re: CD Cleaner/ Polish?
« Reply #1 on: November 22, 2019, 05:34:17 AM »
If you take a small dab of any automotive compound cleaner it will do the same thing. All they are are polishers to gently remove any scratches or imperfections in the clear plastic surface of the disk.
Sure you can pay more for something "audiophile" but a simple car compound is far cheaper and the same thing. Not wax, use the compound.
Offline Guy 13
  • Audio should be simple !
« Reply #2 on: November 22, 2019, 05:42:10 AM »
Hi BobM,
can you mention a brand ?
I am not sure exactly what you mean by : Compound.
Guy 13
Grace Digital Mondo RIT
Cambridge Mini sub 2.1
Schiit Fulla 2 DAC
Schiit SYS PCC
Lot more stuff on storage
« Reply #3 on: November 22, 2019, 05:48:54 AM »
« Reply #4 on: November 22, 2019, 07:19:28 AM »
If I were to use an automotive polish, I'd go for a "Plastic" polish, they are of a finer grit than paint polishing compound, and designed for plastics not paint.
https://www.google.com/search?q=plastic+polishing+compound
« Last Edit: November 22, 2019, 07:24:16 AM by Barry (NJ) »
« Reply #5 on: November 22, 2019, 08:02:15 AM »
Good point.  I've used PlastX on my motorcycle windshield for many years.  Works well, and less abrasive than car polish.
« Reply #6 on: November 22, 2019, 10:23:23 AM »
  Good to know about plastic polish.
Offline dBe
« Reply #7 on: November 22, 2019, 10:37:09 AM »
Mothers Plastic Polish...
http://www.mothers.com/02_products/06208.html#&slider1=20
Fills in micro flaws and leaves the shiniest surface of any polish I've tried.  I used to use Novus Tend, but Mothers is better.
Offline Guy 13
CD Cleaner/ Polish?
« Reply #8 on: November 22, 2019, 01:42:36 PM »
Hi all and thanks all.
Now I have an idea to what look for.
Guy 13
Schiit Fulla 2 DAC
Schiit SYS PCC
