Author Topic: Fun with materials  (Read 10836 times)
Fun with materials
« on: October 04, 2019, 08:48:08 AM »
Fun with materials.
What happens when you put an accelerometer on a piece of MDF and hit it with a ballpeen hammer. Lets take a look.
Audio spectrum 64K point FFT of piezoelectric acclerometer with CLIO.
Love hitting stuff and see what happens! :)
  • Moderator
Re: Fun with materials
« Reply #1 on: October 04, 2019, 09:42:47 AM »
That’s an interesting and fun test.... and also useful if you’re having a bad day  :D 🔨
« Reply #2 on: October 04, 2019, 09:46:15 AM »
Hal, I want to get some accelerometer's to start experimenting, could you recommend some?
« Reply #3 on: October 04, 2019, 03:15:31 PM »
Digikey has one like the Audiomatica CLIO version that needs power to run.  Has a different connector, so will not work directly with CLIO.  It does have sensitivity data usually.
https://www.digikey.com/product-detail/en/te-connectivity-measurement-specialties/1-1001220-0/MSP1001-ND/279641
They sell a preamp, but that has a lot of gain that might not be what is needed.
Hope that helps.
« Reply #4 on: October 04, 2019, 03:42:46 PM »
Fun with materials.
Thank you Hal for performing the experiment and sharing the results with us. The results are quite interesting.
May I ask the type, thickness, size of the MDF? If proprietary, I understand.
Cheers and great weekend.
« Last Edit: October 04, 2019, 03:45:28 PM by steve »
« Reply #5 on: October 06, 2019, 07:46:58 AM »
Fun with materials.
Steve,
Standard 1/2" MDF from Lowes.  Nothing special.  Going to try the oak I used for another baffle and see what it does. in comparison.
« Reply #6 on: October 06, 2019, 09:30:22 AM »
Fun with materials.
Steve,
Thanks again Hal. Comparing this to oak should be very very interesting. What L x W dimensions were used?
This is good information for those who are building their own speakers, even if dimensions are different. In this experiment, virtually no spikes except at very low frequencies, which can be remedied.
Cheers and thanks again Hal.
« Last Edit: October 06, 2019, 09:38:31 AM by steve »
« Reply #7 on: October 06, 2019, 12:16:02 PM »
New test jig for sample testing.
« Reply #8 on: October 09, 2019, 11:36:23 AM »
  A Mad Scientist you are Hal. Love it.
« Reply #9 on: November 14, 2019, 05:24:49 AM »
Have a new test setup built to start testing more samples sent by folks.
Once I get it tweaked will post more data.  Also going to use some constrained layer damped materials to compare.  Should be interesting.
« Reply #10 on: November 14, 2019, 08:55:47 PM »
Yes indeed. Looking forward to your experiments and data Michael.
« Last Edit: November 14, 2019, 08:57:22 PM by steve »
« Reply #11 on: November 15, 2019, 04:52:21 AM »
Ummm.  I am Rich not Michael.
Offline Guy 13
  • Audio should be simple !
« Reply #12 on: November 15, 2019, 05:02:18 AM »
 :rofl:
 :duh
Guy 13
Grace Digital Mondo RIT
Cambridge Mini sub 2.1
Schiit Fulla 2 DAC
Schiit SYS PCC
Lot more stuff on storage
Offline AJ Soundfield
    • Soundfield Audio
« Reply #13 on: November 15, 2019, 06:59:12 AM »
I thought you were HAL???
I've been tempted to take a hammer to some of my creations on more than one occasion. Not for testing though...
Loudspeaker Manufacturer
« Reply #14 on: November 15, 2019, 07:32:55 AM »
Stands for Hollis Audio Labs.  I am Rich, you can call me HAL.
Dave, I cannot do that...
