Author Topic: Jupiter Copper Foil Paper and Wax Capacitors  (Read 7028 times)
Re: Jupiter Copper Foil Paper and Wax Capacitors
« Reply #15 on: February 09, 2021, 11:02:45 AM »
Big fan of Mundorf SGO's here.
I am testing 47uf EVO and EVO in oil (speaker crossover). Needed lots of break in and so far so good. Will be checking for any harshness/edginess as they are very revealing. I am going to use one or two in my upgraded Modi 2. I also need to test smaller values to see how they fare as I would use them in Future 10A/11A if I decide to restart manufacturing.
« Last Edit: February 13, 2021, 09:08:32 PM by steve »
« Reply #16 on: February 09, 2021, 11:39:35 AM »
Interesting, Steve. I’m curious how much more you can get out of your modded Modi 2
« Reply #17 on: February 13, 2021, 09:26:17 PM »
Nick, I had the Mundorf EVO caps in the speaker xover and they were excellent. I then removed and installed the pair in the upgraded Modi 2, in parallel with other ps caps, with good success, but again none in the speaker xover.
I may go exclusively Mun caps both in supply and output for consumers since I cannot get my favorite caps, but the sound of the smaller Muns will have to be spot on. If not, then I will not be offering an upgrade to other's Modi 2 dacs.
Right now, the sound is simply unbelievable. I don't even think about using any other dac.
I have reinstalled the EVOs back in my speaker crossovers, and have another new EVO pair coming mid week so
I will have Muns in both the xovers and Modi 2 (after breakin). The sound could be even better but could also be worse if the Muns are not near perfect.
I am being quite careful to gradually add Muns and note the effects.
ps. I updated my post since Nick posted #18 below.
« Last Edit: March 21, 2021, 04:58:21 AM by steve »
« Reply #18 on: February 13, 2021, 10:50:46 PM »
Nick, I had the M caps in the speaker xover and they were excellent. I then removed and installed the pair in the upgraded Modi 2, in parallel with other ps caps, with incredible success. I may go exclusively Mun caps both in
supply and output for consumers since I cannot get my favorite caps, but the sound of the Muns will have to be
spot on, or I will stick with what I am using now.
I have reinstalled the EVOs back in my xovers, and have another new pair coming mid week so
I will have Muns in both the xovers and Modi 2 (after breakin). The sound could be even better but could also be worse if the Muns are not near perfect. I am being quite careful to gradually add Muns and note the
effects.
Thanks, Steve. Amazing what can be done with an inexpensive DAC. Pls keep us posted
