Author Topic: Jupiter Copper Foil Paper and Wax Capacitors  (Read 6970 times)
« on: September 30, 2019, 07:30:06 PM »
I have been testing the Jupiter copper foil paper and wax 100 volt capacitors and not bad. Somewhat accurate in absolute terms.
Cheers
« Last Edit: July 01, 2020, 04:19:24 PM by steve »
Re: Jupiter Copper Foil Paper and Wax Capacitors
« Reply #1 on: October 02, 2019, 02:16:47 PM »
I agree, they are pretty darn good. I used Amp Ohm paper and oil caps whenever I wanted a sweet and transparent sound on my phono preamp, but they went out of business about 10 years ago and you can;t get them anymore. They were very highly regarded at the time. I then put in the Jupiters and ... when switching between them and the Amp Ohms - there is very little difference. Both great caps.
« Reply #2 on: October 02, 2019, 03:45:03 PM »
Has anyone compared the Miflex Cu in oil to the Jupiters.  I"ve been thinking about trying some in a crossover.  They're about 1/2 the price of Jupiters.
« Reply #3 on: October 03, 2019, 03:15:16 PM »
I am with you Scott. I like the higher temperature rating for stability and long life. But I also wonder how they sound compared to Jupiter and Duelands. Is they are as accurate as the Jupiter capacitors at less price, that would be fantastic.
Caveat: I have not tested a 600 volt Jupiter copper foil paper and wax capacitor.
« Last Edit: October 03, 2019, 03:17:37 PM by steve »
« Reply #4 on: October 10, 2019, 10:39:02 AM »
   Steve I have a pair of 1.0 600V Duelund CAST copper caps sitting here doing squat right now. Switched to hybrid copper silver version foe awhile. Would you like to experiment with them ?
I thought I posted this yesterday however maybe did not click on post.
« Reply #5 on: October 10, 2019, 08:31:00 PM »
Yes, kind of in between values but I can perform a test and get a feel of the sonics. Right now I am using the Jupiter caps in my Modi 2 mod, with absolutely spectacular results.
I will you a PM with my address.
cheers and thanks Charles.
« Reply #6 on: December 17, 2019, 07:14:31 AM »
I am testing the Mundorf M Supreme capacitor for use in a Modi 2 upgrade. I have also been testing a Jupiter copper foil paper in wax capacitor.
The Jupiter capacitor is a copper paper in wax, 2,2ufd 100 volt with many many hours. The Mundorf capacitor is an M Supreme 3.3uf 600 volt with approximately 50 hours. Although the Jupiter capacitor is smaller in value, the tonal balance is fuller. Right now I would say the Mundorf is more accurate, in absolute terms, than the Jupiter.
However, both are excellent capacitors.
There is a high temperature advantage for the Mundorf as well.
I hope this will help when deciding which capacitor to use to improve their system.
« Last Edit: December 17, 2019, 07:16:32 AM by steve »
« Reply #7 on: May 16, 2020, 12:58:15 PM »
   Steve, SORRY MAN. Just forgot. I ordered a pair of .47 Jupiter PIO to try. Still like to try them ?
« Reply #8 on: June 07, 2020, 08:37:53 AM »
  Well picked up Beeswax 600V Jupiter caps to use as a coulping cap to the 211 tube in my amp. We shall see I mean hear it soon. Using V-Cap teflon now.
« Reply #9 on: July 01, 2020, 04:18:25 PM »
Hi Charles.
0,47uf are too small to be of any value to me since I use zero global negative feedback in any of my designs.
Of course, there are uses for such values in other areas of the system.
General information for newbies in electronic components, especially as coupling and output capacitors in components.
0,47uf value, without feedback, and a following 100k ohm resistor as a load,
one is losing 17% of a 20hz signal,
some 8.5% at 40hz,
some 4.25% at 80hz,
over 2% at 160hz, and
over 1% at 320hz.
Besides lack of punch, it will cause a relationship shift of the fundamental and harmonics of instruments etc from
the mids down through the lower regions.
Halve the reactive capacitance value, and percentage listed above for 1uf. 1/4 the reactive capacitance, and percentage listed above for 2uf.
If one checks the value of the coupling and output capacitors in their components, one will be surprised how
small virtually all designers use. The smaller the value capacitors, the more compensation for other mistakes in the design. Db values add if multiple capacitors are used in a system. Something to think about.
I tested a much larger value, with 100 volt DC rating, and found the cap to be a little too full in the bottom. Initial impressions can sometimes be deceiving. I edited my initial post to reflect my initial mistake.
Cheers
« Last Edit: July 01, 2020, 04:56:07 PM by steve »
« Reply #10 on: August 21, 2020, 01:56:06 PM »
   Waaaay over my head. I just listen to them after break in. They take a long time to stop changing. A whole other issue. IMHO most do not put the required hours on new caps. Then give up before reaching full potential. TheDuelunds took 500 hours. V-cap was insane 900+ hours. Van Haus phone was off the hook with complaints.
« Reply #11 on: September 09, 2020, 03:29:15 PM »
But I always have to ask the question, just how good is the sound one is hearing? Good compared to what reference?
I don't need to buy components, but the first question I would ask is what size are the coupling capacitors/output capacitor.
If the reply is less than 3uf, no matter the brand, the music will suffer from what it could have been.
Even broken in, the value makes a difference. That simple 0,47uf coupling capacitor with a 100k grid resistor means
that ~17% of the 20hz bass signal is lost, gone, is across the 0,47uf capacitor. The rest, 83% of the 20hz note is across
the grid resistor. That is what the grid of the tube sees, just 83%. At 160hz, 2% of the musical signal is gone, and even at 320hz, 1% of the musical is gone.
If the grid resistor is half the 100k ohms (50k), then double the losses. If the grid resistor is double the size (220k, which is unlikely), the halve the losses above.
Those losses are from just one stage of coupling. Add a second, third etc to one's system and the losses add. This also
applies to highs as well. The music will always be a compromise to some extent.
Using a small capacitor means the music should be too bright since the bass is reduced. So how does one fill out the music? Three ways. Fatten the bass by coupling capacitor design, truncating the highs of the cap, and improper power supply design. RCA Radiotron Designers Handbook addresses the problem of balancing the highs and bass some 70 years ago or more, so the problem is well known, but evidently not mentioned to audiophiles/music lovers.
Of course, most designs out there would probably oscillate, motorboat if the proper size caps were used. And price, well that is a killer IF the boutique brands are actually accurate, which we don't know. The cost is too expensive to even test, and who can afford the prices of multiple capacitors.
Not surprising that tube amps are known for fat, sloppy bass. Correct the problems, design a proper speaker and the bass tightens right up, and sounds quite accurate/natural, just like it should.
Cheers
« Last Edit: September 10, 2020, 05:22:25 PM by steve »
« Reply #12 on: September 09, 2020, 05:02:11 PM »
Agree with that being insane.  In my house half a decade would go by before the VH caps would settle... and they'd certainly sound different because I'd have lost more hearing.
« Reply #13 on: September 09, 2020, 07:22:19 PM »
Gary Dews offered a cap upgrade on my Border Patrol SE dac using the Jupiters. Am very, very pleased with the results  :thumb:
Offline Brap
« Reply #14 on: January 23, 2021, 07:18:35 AM »
Big fan of Mundorf SGO's here.
Fritz Carrera 7 Be
VTA ST-70
Parasound Halo P5
Oppo 105
Rega P3
Ortofon Quintet Bronze
Cambridge CXN streamer
Teac 3340S
Anticables 3.1
