Author Topic: Stylus Shape and Sound  (Read 3667 times)
Re: Stylus Shape and Sound
« Reply #15 on: October 10, 2019, 01:51:06 PM »
I used index cards for years.  I now use one of those inexpensive Lucite blocks with lines etched in.  Put the block behind the tonearm, set a flashlight to the side and the Lucite block will light up with internal illumination.  Then it's easier to see how the tonearm aligns.  I guess if the tonearm is tapered... buy a USB microscope and try to guess the angle of the stylus?
« Reply #16 on: October 11, 2019, 12:02:03 PM »
  Thanks Clark. Great advice. Where can I get one from ?
« Reply #17 on: October 11, 2019, 01:44:54 PM »
Ok, hold on to your wallet, cause this is going to set you back..... $3.79 including shipping.  Actually, there are several to choose from.
https://www.ebay.com/itm/LP-Vinyl-Record-Player-Measuring-Phono-Tonearm-VTA-Cartridge-Azimuth-Ruler/401657708324?hash=item5d84aa3f24:g:d4IAAOSwx1FcFLZn
There are even some available from Amazon.
I think this is the one I use.
« Last Edit: October 11, 2019, 01:48:11 PM by S Clark »
