Author Topic: NOBSOUND NS-05P Passive Pre  (Read 2553 times)
« on: January 07, 2019, 04:29:43 PM »
   For $56 this little box will surprise and please you. Not the Audio Hungary APR 204 or Lamm LL2.1 however NOT disappointing in the least. If you use SET amp or amp with an input sensitivity of 1A or less and DAC or CDP with over 2V output buy one. Actually buy two for dual mono. Needs 250 hours to stop changing and sound right. Both balanced and single ended in/out.
  If your system has a phonostage use active for that and this for digital.  :thumb: :thumb: :thumb:
Re: NOBSOUND NS-05P Passive Pre
« Reply #2 on: January 16, 2019, 11:29:32 AM »
  Guys if you think this piece is a joke you are greatly mistaken.  One has to spend serious dollars to beat this little thing Actually two is better than one. Run them dual mono and do not look back. If one uses srtictly digital playback has a DAC or Cd player with a 2V minimum output along with an amp with low input sensitivity [ less than 1V or close and not more than 1.5V ].
 You my friend are in like Flynn. IMHO this is a freak of nature. On paper it should be just OK. No I am NOT a dealer and as a dealer F'n nuts telling you about it. But that,s me. No its not a Lamm or Audio Hungary preamp as it does not fit all but if the criteria is there to use it it will be the best $112 you spent on Audio. TT does not apply.
