Author Topic: Tonearm rewire job.  (Read 2126 times)
Tonearm rewire job.
« on: October 20, 2018, 04:10:10 PM »
I've got a tonearm to rewire and have not tackle one before.  It currently has the old wire still barely sticking out, so I can use it to pull some Cardas wire through.  Any issues that I need to be aware of before tackling this??  Who's done this before around here?
Re: Tonearm rewire job.
« Reply #1 on: October 22, 2018, 05:35:49 AM »
No one??  :shock:
Offline JBNY
« Reply #2 on: October 22, 2018, 07:59:01 AM »
The only thing you want to be aware of is making sure you are able to pull the new wire successfully through the tone arm. Some tonearms have damping material in the arm that the wires needs to go through. I solder the new wire to the old and put a thin piece of tape over and it pulls through fine.
Just take things slow and you should be good. It's not a hard procedure it is just time consuming.
-Joe
Equi=core 1800 Balance
