Author Topic: WTB - speaker wire connectors  (Read 1456 times)
« on: August 04, 2018, 01:48:41 PM »
Anyone have any name brand, used is ok, speaker wire connectors they want to turn into cash?
Need 8 banana plugs for speaker side, 8 spade lugs for amp.
Prefer less bulky spades as not a lot of room in back of the amp.
Gene
Re: WTB - speaker wire connectors
« Reply #1 on: August 05, 2018, 04:58:04 PM »
  Gene if you cannot used check out Pangea good and priced fair.
Lamm Industries - Aqua Acoustic, Formula & La Scala DAC- INNUOS  - Rethm - Kuzma - QLN - Audio Hungary Qualiton - Fritz speakers -Gigawatt -Vinnie Rossi,TWL, Mad Scientist, Swiss Cables
Offline Jack
« Reply #2 on: August 06, 2018, 06:22:20 AM »
Vista Phono II
Nuprime CDT-8
Supratek Chardonnay
Vision SET400
Aqua La Voce S3
Auralic Aries G1
Reynaud Abscisse Jubilee
(2) Rythmik F12SE
TWL PC's, USB, SC
Audio Envy IC's, PC's
PSA Stellar P3
Uberbuss
« Reply #3 on: August 06, 2018, 06:32:42 AM »
Welcome back Gene.  :thumb:
VPI HW-19 Mk IV/SDS/SME IV/Benz Micro Glider
Pro-Ject Pre Box S2 DAC/Bluesound Node/Denon 2910
DigiBuss/TWL PC/MIT Cable
« Reply #4 on: August 06, 2018, 07:55:58 AM »
DHLabs also sells very inexpensive connectors, wide selection of spade types. I don't know if they are pure copper or brass but you can ask if that matters to you.
« Reply #5 on: August 08, 2018, 03:38:51 PM »
Good suggestions all, thanks. More concerned with form factor, this is for the Classe 25 I bought from Tmazz, the generic spades I got just don't fit 'right'.
« Reply #6 on: August 08, 2018, 03:49:31 PM »
Thanks Jack, I think I see some Vampire spades that may be just what I need.
Check with Douglas Connections.
https://www.douglasconnection.com/Speaker-Cable-Connectors_c10.htm
« Reply #7 on: August 08, 2018, 03:51:02 PM »
I never left in spirit, I've been watching from afar as Richidoo tries to once and for all settle on speakers.
Offline Jack
« Reply #8 on: August 08, 2018, 04:05:54 PM »
Gene
Give him a call he was easy to work with.  Maybe if you can send him a photo of the rear panel of the amp he can give you better advise.
Vista Phono II
Nuprime CDT-8
Supratek Chardonnay
Vision SET400
Aqua La Voce S3
Auralic Aries G1
(2) Rythmik F12SE
TWL PC's, USB, SC
PSA Stellar P3
Uberbuss
« Reply #9 on: August 08, 2018, 04:40:05 PM »
Never!
But glad you're watching Gene.  :thumb:
« Reply #10 on: August 08, 2018, 06:04:08 PM »
Vampire spades for the amp you got from me?????
Something just sounds very right about that combo.
