Author Topic: speaker cables  (Read 8844 times)
Re: speaker cables
« Reply #15 on: March 21, 2018, 11:50:33 AM »
I did a quick search and found this link at AC
http://www.audiocircle.com/index.php?topic=112044.msg1188669#msg1188669
Robert was listed as cOz and for this link also as HT cOz
Re: speaker cables
« Reply #16 on: March 21, 2018, 12:35:05 PM »
Now that you guys have posted multiple times about "White Lightning Moonshine" cables, my DIY post from earlier doesn't seem so farfetched!  8)
SN
Over the years, I’ve heard nothing but good things about moonshine  :clap:
The cables or the beverage?  8)
Offline Bob in St. Louis
Re: speaker cables
« Reply #17 on: March 21, 2018, 01:03:49 PM »
SN
"Yes".
Re: speaker cables
« Reply #18 on: March 21, 2018, 01:14:14 PM »
SN
I refuse to answer that on the grounds that it may........ 🥂 :beer:
Re: speaker cables
« Reply #19 on: March 21, 2018, 02:11:00 PM »
the liquor or the cable? :rofl:
Re: speaker cables
« Reply #20 on: April 02, 2018, 08:37:03 AM »
My entire system is "White Lightning Moonshine" DIY cables.
Check it out.
http://www.6moons.com/audioreviews/whitelightning/moonshine.html
Canare 4S11 is superior. In fact I have yet to find a reason to upgrade. If I was going to, I'd probably go with ZenWave. They are technically better and use fancy audiophile connectors with better conductivity.
  Superior to what ? What cables have you compared the Canare to ? Did you choose Canare for spec or design reasons or price ? Not breaking your balls just curious. Have you ever tried Nordost, Prana, Crystal Cable ?
djdube525
Re: speaker cables
« Reply #21 on: April 02, 2018, 11:18:23 AM »
Check it out.
Presumably, superior than the prior mentioned/linked "White Lightening Moonshine" DIY Speaker cables
Re: speaker cables
« Reply #22 on: April 02, 2018, 11:44:43 AM »
Check it out.
  Arghaaaa ! How did I miss that.
