Author Topic: The Monolith open baffle planar array  (Read 38007 times)
« on: October 14, 2017, 10:48:28 AM »
Now that GR-Research and the Parts-Express folks have the new Neo3 and Neo10 planar drivers again, back to The Monolith speaker design.
The baffle has the 45 degree wing, but needs felt to work correctly, so making the angle lower as Danny has suggested is the better way to go.  The future is going to work toward the 10 degree version with the GR-Neo3 and PE Neo10 planars.
The 3x8" OB H-Frames are built and next will be installing the drivers and connection to the Rythmik HX300 amps.
The dspMusikLCD will be the digital crossover and entire interface for the system to DC coupled amps the HX300 servo amps with balanced connections.
Picture is with the OB planars on two of the modular 2x12's for The Megaliths.  Both OB servo sub arrays work well with the planars as it is easy to change levels to each amp with the dspMusikLCD.
Re: The Monolith open baffle planar array
« Reply #1 on: October 14, 2017, 04:50:59 PM »
Looks cool Rich!
Is it one tweeter and one mid per side as pictured? Are these OB like the bass?
« Reply #2 on: October 14, 2017, 05:20:25 PM »
Honestly, I've always wondered why Danny hasn't done this in a kit??? It seems like such a no-brainer.
« Reply #3 on: October 14, 2017, 09:04:52 PM »
Yes, one BG Neo3-PDR and Neo10 per side in a winged open baffle with 3x8" servo subs in an OB H-Frame.  Three way digital crossover.
Scott,
My understanding is it was to be a Serenity Acoustics design.  When the BG to Christie sale occurred, no one could get drivers. We all gave up when that happened.  I built prototypes with Danny, Ruben and Ben's help of a two piece design, but had to put it away thinking it would not happen again until Danny and PE got new BG drivers.
Now if someone wants to build baffles, I have a dspMusikLCD crossover for them.  If folks ask Danny now, he might do a kit with one of his passive crossovers that always sound great.   He now has the GR Neo3's available.
This was my prototype to try the BG drivers in an open baffle and that led to The Megaliths after hearing Danny's Line Force speakers with you.  I think the OB H-Frame will be better than the U-Frame I was using before.
« Reply #4 on: October 16, 2017, 09:53:46 AM »
The new GR Neo3 and PE BG Neo10 planars have arrived.
Should have them installed later this week and make measurements for the updated dspMusikLCD crossover.
« Reply #5 on: October 18, 2017, 01:58:57 PM »
GR Neo3's and PE BG Neo10's are here.
Time to install them and make measurements.
Offline AJ Soundfield
    • Soundfield Audio
« Reply #6 on: October 18, 2017, 06:46:49 PM »
Those drivers should make for some nice sound
Loudspeaker Manufacturer
« Reply #7 on: October 18, 2017, 07:13:28 PM »
They do.  Just trying to improve design the baffle at this point.
« Reply #8 on: October 20, 2017, 07:07:07 PM »
The first of two Parasound Halo A23's arrived today.   Should have the second for testing next week with the Monoliths for triamping them.  The Rythmik HX300 servo amps for the 3x8" sub open baffle H-Frames are here.
« Reply #9 on: October 21, 2017, 12:39:15 PM »
Test open baffle and GR Neo3 version planars.  Original Neo10 installed in the baffle in pics
« Reply #10 on: October 21, 2017, 01:39:42 PM »
The Monolith test baffle with the new GR Neo3 and BG Neo10 installed. Next for some wiring and checkout.
« Reply #11 on: October 21, 2017, 02:05:34 PM »
Nice!
You got a CNC?
Do the new drivers sound and measure as good as the old ones?
« Reply #12 on: October 21, 2017, 02:13:41 PM »
No, but Ben who built these does.  That was probably 2 years ago before Christie Digital bought BG and stopped production until this year.
Measurements are next to see how things go.  I expect the GR Neo3 to be different, since it is no a PDR version as made, but the Neo10 should be the same as before.
« Reply #13 on: October 22, 2017, 05:32:35 AM »
Yes, going to install the yarn after the first set of measurements.
They are basically stock Neo3's at this point with the new diaphram material.
« Reply #14 on: October 22, 2017, 07:10:05 AM »
The planar mid and tweeter are wired and ready for testing. The 14awg polyolefin insulated wiring has been very easy to work with for the drivers.
Now to connect up to the Parasound A23 and see if we let out any magic smoke. If not, measurements.
Next is wiring up the two 3x8" servo sub arrays and HX300 amps.
