Author Topic: Component Enclosures  (Read 3576 times)
« on: August 17, 2017, 01:04:27 PM »
  Metal, wood other none. Lots of choices with what to offer in selection ? Lately removed covers from amps as per Michael Green recco. Sounded more open and focused. Go figure. Any thoughts ??
Offline _Scotty_
  • “Sic transit gloria mundi”
Re: Component Enclosures
« Reply #1 on: August 17, 2017, 01:45:16 PM »
Hey Charles, which amps does this help?
« Reply #2 on: August 17, 2017, 03:11:08 PM »
I remember Michael Green from years ago and he was one of the first to get into component vibration. Iirc, he used some strange looking, clamp like devices back then. If he also made speakers, I think he came to my house in so California to demo his speakers. They had a curved top that looked like an old, vintage radio. Had to be placed away from the side walls, so I didn't buy them
Offline Folsom
« Reply #3 on: August 17, 2017, 08:53:52 PM »
Maybe less vibration, maybe benefits from more RF.
« Reply #4 on: August 18, 2017, 10:31:34 AM »
  According to Green All amps. It was pretty obvious to hear. In my case the Arion HS 500 class"D" hybrid.
« Reply #5 on: September 12, 2017, 07:40:57 AM »
I know this suggestion is not a "cabinet", but I have my stereo currently in a rack. I followed a suggestion by an audiophile friend and purchased some 12" diameter bicycle inner tubes. Fill 7/8 full or so, not critical. Clearly made a sonic difference. Can purchase inner tubes for ~$3.75 at Walmart, bicycle section.
Cheers
Steve
« Last Edit: September 12, 2017, 07:45:04 AM by steve »
« Reply #6 on: September 12, 2017, 08:04:10 AM »
  The ole inner tube trick eh. Remember Arcicci ? Still have two airheads. Very effective with tubed gear. The most effective has been a wood box filled with sand with a wood plinth resting on sand. TT's really benefit with the sand box.
  Back to enclosures. Do we want a microphonic sound from that metal box when hit or one that is dead quite ? Some prefer the microphonic sound.
  D. Berning likes perforated alum. Others SS or heavy ga. steel. Th enclosure type makes a difference in overall sonics. Is it RFI protection, resonance, looks or all of the above ??
DRN
« Reply #7 on: September 12, 2017, 08:54:07 AM »
MG also says to loosen your speakers in their cabinets. AND remove your wall outlets and let them hang out of the wall.
Crazy  (stoopid  dangerous) stuff.  :shock:
Not going there.
Every once in a while he surfaces on the boards.
Offline AJ Soundfield
    • Soundfield Audio
« Reply #8 on: September 12, 2017, 10:05:04 AM »
I'm ok with not loosening my screws. Just saying...
Loudspeaker Manufacturer
« Reply #9 on: September 12, 2017, 11:06:04 AM »
   They are loose enough already :roll:. Couldn't help help myself  :D
Offline Response Audio
    • Response Audio
« Reply #10 on: September 13, 2017, 08:09:51 AM »
It really depends on the type of control you use. If you want to couple, you want everything tight to allow the vibration to make its way to and out the coupling devices used, such as Audio Points or other coupling devices.
When goung the decouing route, using damping material and a decoupling technique such as Herbies or a sanebox works very well.
You dont normally want to mix the two concepts in my opinion. Linning a chassis with damping material and setting it on audio points or other cone type fefeeand then on a hard shelf is defeating the purpose and a waste of money for the points.
There are some ways of combining these concepts that actally do work. Using the coupling technique and then setting on a sandbox works very well. This allows all the energy to transfer out of the component and allow the sand box absorb it all.
It really is a combination of science and art and done right, you will get great results.
Design Engineer
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
« Reply #11 on: September 15, 2017, 08:06:19 AM »
Could not agree more, thanks for the input Bill. Love my sand boxes.
« Reply #12 on: September 15, 2017, 12:30:49 PM »
What you said.  I still love the sandboxes.  Oh, we have no cats.
