Author Topic: KT150  (Read 17340 times)
Offline Hugh
    • Angel City Audio
Re: KT150
« Reply #30 on: August 04, 2017, 06:31:00 AM »
If and when you get a chance, compare the KT150 against a 845 based amp.
I never even heard of a 845 based amp. What is that?
845 tube.
Hugh Nguyen
Angel City Audio
Offline spm3
Re: KT150
« Reply #31 on: August 04, 2017, 06:36:05 AM »
Re: KT150
« Reply #32 on: August 04, 2017, 07:48:35 AM »
Nice, Shawn. Very nice. As I'm not a tube guy, these need how many hours to sound decent??
Come on over Nick. ;)
A tempting offer  :drool: You know so Cal is my old stomping grounds. Would love to hear some of those tube amps I see on your website
Come to THE Show in Anaheim in September then.
Hugh,
I am trying to make that happen. Looks good so far.
Offline Hugh
    • Angel City Audio
Re: KT150
« Reply #33 on: August 04, 2017, 08:31:32 AM »
Hugh,
Let me know so I can get you a badge.
Hugh Nguyen
Angel City Audio
Re: KT150
« Reply #34 on: August 04, 2017, 12:45:15 PM »
Hugh,
Badges? Badges? I don't need no stinkin' badges!! Umm, sorry..classic movies flashback 😀😀
I appreciate that, Hugh.
Re: KT150
« Reply #35 on: August 05, 2017, 06:30:31 AM »
Re: KT150
« Reply #36 on: August 05, 2017, 08:03:25 AM »
Tom,
You don't like the University of Wisconsin??? Can hardly wait for college football to start...but I digress
....again  :roll: :roll:
Offline spm3
Re: KT150
« Reply #37 on: August 07, 2017, 11:12:31 AM »
Okay, these tubes are insane!
These tubes now give a new depth to the music I've been listening to. I can hear notes that I haven't heard before, and the bass is so solid!
My system sounds like never before - I can't believe it!
I 100% recommend these tubes. They are great!
Re: KT150
« Reply #38 on: August 07, 2017, 07:30:12 PM »
They seem to be ARC's tube of choice right now, so you are not the only one who likes them. But , that said, as I mentioned before they have much higher current requirements in terms of both output and operating currents (bias and filament) so even though they are pin compatible with other EL34/KT-88 tubes, there are not a lot a amps that can use them as a plug in replacement for the tubes they came out of the factory with.
Re: KT150
« Reply #39 on: August 08, 2017, 10:29:45 AM »
That filament is what worries me in most amps. The tubes could be biased conservatively for less plate current, thus not overloading the power supply, but I wonder if the sonics will suffer?
In my monoblock amps, I am currently running either Winged Cs/Bugleboy E88CC, or with a slight adjustment, SED KT88s/JJ E88cc, they both sound incredible. Some day I would not mind trying the KT 150s to see how good they are but with the unbelievable sound of the KT88s, I don' t see any great need.
Cheers
Steve
« Last Edit: August 08, 2017, 10:57:42 AM by steve »
Re: KT150
« Reply #40 on: August 08, 2017, 10:53:05 AM »
Great news, Shawn. I was hoping they would sound great for you. Any idea when you would need to retube?
Re: KT150
« Reply #41 on: August 08, 2017, 10:11:03 PM »
Cheers
Steve
Hey, if it ain't baroque, don't fix it.
Re: KT150
« Reply #42 on: August 09, 2017, 04:02:39 AM »
Tom, i believe shawn was between a rock and a hard place  :duh
Offline spm3
Re: KT150
« Reply #43 on: August 09, 2017, 06:47:36 AM »
Nick,
From what I understand, they last about 3k hours with my PrimaLuna. So maybe 3 years depending on amount of use?
I'd say it will last me closer to 3 years before I would need to retube
Shawn
Offline Hugh
    • Angel City Audio
Re: KT150
« Reply #44 on: August 09, 2017, 09:05:31 AM »
FWIW, my original Melody SHW1688 Pre still has the original tubes after more than 15 years or so of constant use.
Hugh Nguyen
Angel City Audio
