Author Topic: Sharing Top Notch, Reference Music Links.....  (Read 95985 times)
Re: Sharing Top Notch, Reference Music Links.....
« Reply #330 on: February 02, 2023, 01:55:46 PM »
This recording provides a lot of individual instruments, even if for just a short period. Although
not perfect, one should be able to distinguish the various instruments. Example, horn, trombone,
trumpet and other instruments.
https://www.youtube.com/watch?v=WCmAIMgNon4
Almost forgot, I did not look for higher rez.
Cheers
« Last Edit: February 02, 2023, 01:59:02 PM by steve »
Offline GDHAL
« Reply #331 on: February 03, 2023, 05:14:34 PM »
Cheers
Hi Steve, thank you for this...it's a beautiful piece of music... Well recorded both sonically and video wise. To your point about looking for a higher resolution the link you provide is the YouTube default of 480p. You can use the settings to increase it to 1080. But that's just the video piece. I don't think that the audio quality can be increased. Well, not via YouTube anyway. I'll concede the audio is certainly good enough to be very enjoyable.
EDIT: and kudos are in order for the concertmaster first chair violinist.
« Last Edit: February 03, 2023, 08:06:48 PM by GDHAL »
http://halr.x10.mx/other.html
« Reply #332 on: February 04, 2023, 06:42:12 PM »
Cheers
Yes, the first violinist is very good. I have YT premium which does give a little better musical quality. I don't worry to
much about the video. As mentioned, settings can be set for higher rez.
Too busy to check deezer or Tidal. Over the decades I have been surprised at how many systems cannot
differentiate a trombone from horn etc.
Anyway, love the variety of instruments to check.
« Reply #333 on: February 07, 2023, 07:21:32 PM »
Difficult to describe this selection, except to say it is so open, natural, precise, not slurred nor raspy,
but the room acoustics should just "glow" with every note. One should feel they are experiencing the
actual event.
Even though it appears that lower midrange and upper bass are being reproduced, this selection requires
very flat frequency response/phase coherency over a wide frequency range to experience the reality of this event.
Enjoy.
https://www.youtube.com/watch?v=2KYJC8Hw9i0
Did not look for high rez.
« Last Edit: February 07, 2023, 07:35:29 PM by steve »
Offline GDHAL
« Reply #334 on: February 08, 2023, 03:27:00 AM »
actual event.
Enjoy.
Hi Steve.
Great choice! Mickey Hart, The Gates Of Dafos. I mentioned that in this thread https://www.audionervosa.com/index.php?topic=8689.msg107796#msg107796
If you like, I'll be more than happy to provide you with a rather splendid recording (vinyl remaster 1644, in digital format) of it. In addition to your description, when played at the proper decibel level - which IMO is 90-105 db - the recording has an uncanny way of exciting the environment/room, which can uncover unwanted resonances that should subsequently be fixed/addressed.
Stereo subs, anyone?  :thumb:
« Reply #335 on: February 09, 2023, 05:50:07 AM »
actual event.
Enjoy.
Hi Steve.
As long as on CD, I can pm my address to you if you ok. One reason I like Deezer is that I don't have to
download and add a program like I had to with Tidal. I am still finding remnants of that program.
With deezer, simply sign in, play music.
« Reply #336 on: April 06, 2023, 06:35:52 PM »
This is one nice Vivaldi selection, plus a little more. Very spacious, soundstage, natural sounding.
https://www.youtube.com/watch?v=puMBpccmGBA
« Last Edit: April 07, 2023, 04:01:40 PM by steve »
« Reply #337 on: April 06, 2023, 09:34:09 PM »
Thanks, Steve. That was very nice.
« Reply #338 on: April 07, 2023, 02:07:06 PM »
Here is another I just found and love. What a venue, and sounds great
even through YT. Notice the volume changes near the beginning.
https://www.youtube.com/watch?v=hyqan5fcOkA
I hope I did not create too much bias in my above post. I have a question and hope any and all will reply
with their thoughts. No wrong or right answer.
Did all the instruments sound ok? Did anything seem even slightly out of sorts?
« Last Edit: May 23, 2023, 12:33:38 PM by steve »
« Reply #339 on: May 23, 2023, 12:44:11 PM »
This next selection can be found on YT, Qobuz, and Deezer. A little different version of Take Five
than what one normally hears. Be sure to read the "show more" section. Recorded 1959.
Pay attention to the cymbals, bass, spaciousness.
https://www.youtube.com/watch?v=0xaBMKDQov4
Cheers
« Last Edit: May 24, 2023, 08:35:49 AM by steve »
« Reply #340 on: June 16, 2023, 04:57:55 PM »
A nice selection from Vivaldi, Ciaccona in C Major, by Apollo's Fire, live in Cleveland.
The spaciousness/soundstage etc.
https://www.youtube.com/watch?v=SBYSuHICBIE
« Reply #341 on: June 16, 2023, 10:30:43 PM »
Thanks, Steve 👍
« Reply #342 on: June 25, 2023, 08:05:04 PM »
This selection is minimalist recorded. All I can say is that I can easily believe I am at the venue.
https://arizonachambermusic.org/videos/jackie-glazier-clarinet-ivan-ugorich-viola-fanya-lin-piano/
Cheers
« Reply #343 on: June 26, 2023, 12:24:35 AM »
Cheers
Thanks, Steve. Very nice 🎶
Offline GDHAL
« Reply #344 on: June 26, 2023, 03:48:33 AM »
Cheers
Nice. I have no doubt the recording would sound even better, much better in fact, if performed and subsequently recorded in a professionally treated and purpose built environment as opposed to the austere San Pedro Chapel.  :thumb:
