Author Topic: Apogee Bliss  (Read 3682 times)
Apogee Bliss
« on: March 13, 2013, 08:20:37 AM »
  If you own Apogees than by all means check out Symo Cabling. It is highly recommended for Apogees. Especially bi wired.
   Apogees are known to be cable sensitive. Usually makes or breaks them according to the Apogee Gurus.
   Other contenders are , Straight Wire and Kimber.
Lamm Industries - Aqua Acoustic, Formula & La Scala DAC- INNUOS  - Rethm - Kuzma - QLN - Audio Hungary Qualiton - Fritz speakers -Gigawatt -Vinnie Rossi,TWL, Mad Scientist, Swiss Cables
Re: Apogee Bliss
« Reply #1 on: March 19, 2013, 09:23:05 AM »
  Spectral amps are the Apogees meow. Wonderful synergy with Apogee. With the warm character of the Apogees the cool dead neutral Spectral Amps are glorious. Actually the designers choice when demonstrating.
Re: Apogee Bliss
« Reply #2 on: March 19, 2013, 06:27:51 PM »
Re: Apogee Bliss
« Reply #3 on: March 20, 2013, 06:23:43 AM »
By all means a very sensitive and revealing speaker. Yes, everything makes a difference. A real PIA to set up too (1/4" changes make a huge difference) but once you've got it, you've got it.
Everyone should hear a restored Apogee, if for no other reason than to see what was truly possible 20-25 years ago and how the passing of time hasn't truly improved things a lot, as far as planer/ribbon speaker design is concerned.
Re: Apogee Bliss
« Reply #4 on: March 20, 2013, 07:32:08 AM »
  Yes the Krell KSA series were VG amps. A tad on the warm side of neutral. They sounded great with my old Mirage M1si speakers.
    Apogees seem to sound there best with a cool or neutral amp. The advancement of magnets and use of metalized mylar have come a long way.
Offline topround
Re: Apogee Bliss
« Reply #5 on: March 20, 2013, 09:54:02 AM »
i know just the man to restore the krell, his name is steve and he built krells for a living back in the day when he worked for krell, "the service dept", he is in ct.
Re: Apogee Bliss
« Reply #6 on: March 20, 2013, 11:18:43 AM »
   I believe he fixed my Lector CDP , laser you know.  Good guy.
Re: Apogee Bliss
« Reply #7 on: March 21, 2013, 09:29:42 PM »
Got it...
http://www.theservicedepartmentct.com/
Thanks Mike... :thumb:
