Author Topic: Placement and speaker loudness (volume)  (Read 11079 times)
Offline Werd
« on: November 15, 2010, 08:42:42 AM »
I find one of the biggest challenges in my basement is trying to achieve good imaging at all volume settings. I see a whole lot of room pics with different acoustic treatments. But i never seem to hear about how these speaker placements and treatments effect the volume for imaging. I am an image freak so this is paramount. I am about to start some acoustic paneling i think volume settings are where its at for a strategy. But i am a newbie with paneling so help me out....
Re: Placement and speaker loudness (volume)
« Reply #1 on: November 15, 2010, 08:52:16 AM »
If the setup is right, the speakers are not stressed, and the room is treated properly, the imaging should not change at different volumes.
Offline Werd
« Reply #2 on: November 15, 2010, 08:56:11 AM »
Is it cheaper to treat for the sweet spot or do i need to panel for the whole room?
Thanks Bryan
« Reply #3 on: November 15, 2010, 09:00:05 AM »
Where do you listen?  That's where you need to treat for.
Offline Werd
« Reply #4 on: November 15, 2010, 01:08:04 PM »
Hi
I have my system in the corner and the speakers pointing towards the center of the room. I own a ht 3 seater chair unit. I have them about 1/3 in and sort angled to the corner. I should take a pic.
« Reply #5 on: November 15, 2010, 04:09:39 PM »
One of the best things I ever did for my imaging was to  nail down my speaker placement using the in phase/out of phase tracks on the Sheffield Test disc. Movements of as little as a 1/4 inch (6.35 mm to you guys  :D) made big differences in both soundstage size and locational focus. I thought I had it sounding pretty good just doing it by evaluation random changes and trying to stumble onto the right spot, but when I used the step by step changes with the test disc, it guided me to the best spot and when I hit it, everything just locked into place.   :yay2:
« Last Edit: November 15, 2010, 04:12:16 PM by tmazz »
« Reply #6 on: November 15, 2010, 04:21:01 PM »
Which Sheffield Test disc are you referring to? There were a few of them when I googled.
« Reply #7 on: November 15, 2010, 04:35:43 PM »
Barry,
I looked at what was on google and I don't see the one I have. The Reference Recordings/XLO disc is similar and has the same in/out of phase tracks, but my disc is not gold. I am at work tonight, but will take a look on the shelf when I get home and get you the exact title.
« Reply #8 on: November 15, 2010, 05:08:46 PM »
Thanks Tom!
« Reply #9 on: November 16, 2010, 07:06:04 PM »
The one I have is the "Sheffield / XLO Test & Burn in CD" It is listed on Amazon at:
http://www.amazon.com/Sheffield-Xlo-Test-Burn-CD/dp/B000025RLX/ref=sr_1_1?ie=UTF8&s=music&qid=1289962512&sr=1-1
Used copies can be had for under $10
There is also a Reference Recordings/XLO disc which is a gold CD. It has different music tracks but from what I can see on the contents listing on Amazon, the first few tracks are the same kind of in-phase.out of phase tests (although I have never heard this disc myself , so I can't know for sure
« Reply #10 on: December 04, 2010, 09:53:46 AM »
Barry,
  That is the one. When that out of phase signal comes from "all around the room" the imaging result is great. As a Pipedream owner imaging plays a key part to my listening pleasure.
   a no brainer.
« Reply #11 on: December 07, 2010, 10:03:27 AM »
If the imaging/soundstaging changes with volume then you are probably getting some untreated bounce from sidewalls or front/back walls. It's a sure sign that you need some treatments.
(then again, our SO's continue to say we all need "treatment", no doubt  :-({|=)
« Reply #12 on: December 07, 2010, 02:45:05 PM »
Thanks for the link and info Tom!
Offline Werd
« Reply #13 on: December 07, 2010, 04:15:36 PM »
I was wondering about that
« Reply #14 on: December 08, 2010, 05:26:19 AM »
My wife always tells me it's not a hobby, it's a sickness.......  :rofl:
