Author Topic: Bye Bye HDMI  (Read 14088 times)
Offline RichardS
Re: Bye Bye HDMI
« Reply #1 on: July 03, 2010, 06:02:21 AM »
Interesting. Guess I'll put off that new projector/ new receiver purchase for a while. Sounds like it may be a serious cost benefit for the longer runs usually required for projectors (have you seen the prices of the long run specialty HDMI?).
My Northstar transport/ DAC uses ethernet to transmit its i2s audio signal. I haven't experimented with upmarket ethernet cables, though I find generic 12s sounds better than inexpensive coax.
« Last Edit: July 03, 2010, 08:57:30 AM by RichardS »
Black Sand Cable
Re: Bye Bye HDMI
« Reply #2 on: July 03, 2010, 10:23:24 AM »
It may be rolling out in 2011, but I would bet a fair bit of change that it will take a few years before it's common place.
I actually like the idea but I seem to recall thinking laser discs, DVD-A, HD-DVD, HDMI and a few others were also cool!  :lol:
djdube525
Re: Bye Bye HDMI
« Reply #3 on: July 03, 2010, 02:56:11 PM »
Forget cables all together... a projector with 802.11n would make life a heck of a lot easier...
Re: Bye Bye HDMI
« Reply #4 on: July 05, 2010, 05:26:26 PM »
Can wireless handle high def in real time?  I wouldn't think it'd be seamless.
I really like the RJ45 idea.. I wondered why they hadn't already done this... I also wondered why they didn't use RJ11/phone cable for USB... It's just weird how companies rush to waste resources rather than use something that exists... just so they can market it (lie) to get more money.  Oh well, as long as there are people without much other choice, there will always be a market.
Re: Bye Bye HDMI
« Reply #5 on: July 05, 2010, 10:09:57 PM »
I had the same though about the adequacy of wireless bandwidth for  transmitting HD video.
As for the RJ11 jack, IMO it was passed over for us with USB because it is not rugged enough for frequent insertions and removals. Lets remember what  the RJ11 was originally designed for, to connect a telephone to a wall jack. In that application the phone is most often plugged in and left undisturbed for years. The little locking tab on the RJ11 would never stand up to the number of insertions that many USB cables have to endure.
Re: Bye Bye HDMI
« Reply #6 on: July 06, 2010, 05:53:19 AM »
Well, you can always future proof and run multiple runs of Cat 5 or Cat 6.  2 runs with a balun on each end will allow you to do HDMI now and then swap over without rewiring when the new standard kicks in.
Re: Bye Bye HDMI
« Reply #7 on: July 06, 2010, 05:57:18 AM »
Damn you're smart!   :thumb:
Re: Bye Bye HDMI
« Reply #8 on: July 06, 2010, 07:13:43 AM »
http://www.keydigital.com/IW_Products.m4p.pvx?;ITEM?ItemCode=KDCATHD&Company=KEY
Not smart, just know how to use Google on a big job I'm doing that needs LOOONG HD runs from a video server.
 :-k
djdube525
Re: Bye Bye HDMI
« Reply #9 on: July 06, 2010, 04:50:41 PM »
Well... I would think 802.11n would do...
I have a roku box in our bonus room which is completely on the opposite end of the house, and different floor of the house as our wireless router which is 802.11g... and the signal strength is roughly 50%. Granted... roku is buffered, but everything we stream is in HD. However, with the much faster rate, and better range, I would think 802.11n would suffice.
Offline Bob in St. Louis
Re: Bye Bye HDMI
« Reply #10 on: July 06, 2010, 06:58:32 PM »
Interesting topic.
Eight years ago when I built this house, I spread 1,000 feet of Cat5e throughout. A good majority of it from various places in the HT room to the main equipment rack area. Also, made runs from most of the rooms in the house to a centralized closet in the basement. My thinking was "eventually", I'd run whatever without breaking a sweat.
Along comes WiFi.......Ended up using half the cable for phone, the other half just dangles not doing anything.
Would be cool if it turns out I could use it and find out I was having a good idea eight years ago.  :rofl:
Bob
Re: Bye Bye HDMI
« Reply #11 on: July 06, 2010, 08:53:05 PM »
Me too, Bob, but I also ran 8 zones of speakerwire.  :duh   That was before I knew that 16ga plenum speaker wire isn't really speaker wire and before wireless media players entered my life. I use only one set of the speaker wires going to the back porch. And maybe someday the garage too, but probably none of the others. Technology marches on....
Re: Bye Bye HDMI
« Reply #12 on: July 07, 2010, 05:24:25 AM »
Yea, I ran several myself.  Like you, I only used one as well.  :lol:
Oh well, live and learn.
Bob
Re: Bye Bye HDMI
« Reply #13 on: July 07, 2010, 05:33:09 AM »
Now that I think about it the biggest problem with using 802.11n might not be bandwidth, but rather interference and channel contention. Along with the higher throughput, 802.11n also brought us wider coverage than previous 802.11 incarnations. If everybody and his brother starts using it for TV connections there is a good chance you will start seeing users overlap on another , especially in higher density housing areas like apartment buildings, townhouse complexes or even just urban and suburnan areas where homes are close together (typical property sizes an Long Island are in the area of 60' x 100' plots) I don't know how many channel they designated in the final 802.11n standard but I would be surprised if it was much more than a dozen or so. And the wider the coverage gets the more likely you and a neighbor will end up contending for the same channel. This could end up being the biggest problem with using wireless in a Metro area.
manaox2
Re: Bye Bye HDMI
« Reply #14 on: July 07, 2010, 03:16:11 PM »
You could always do HDMI over Ethernet if your wired. Its not too expensive. Run USB over Ethernet while your at it. You know, in the meantime.
