Author Topic: Audience AR1P  (Read 2912 times)
Black Sand Cable
Audience AR1P
« on: December 06, 2009, 11:55:57 AM »
I have two of these fantastic little boxes up for grabs. Both are brand new.
These are hands down the best "Little" box out there at the moment and I have tried just about all of them. I should also note that they are an Aboslute Sound Golden Ear Award Winner.
Specs from Audience:
This hand-built single outlet power conditioner from Audience is built to the same standards as the aR6 and aR12. The aR1p is exceedingly versatile; designed for single component applications like amplifier or monoblocks. It plugs directly into the wall (no power cable required) and can be easily used with a multi-outlet strip to protect and enhance an entire system. By greatly reducing power line noise, the aR1p provides a lower noise floor and blacker background, resulting in a much higher level of resolving system characteristics.
• Dynamic range performance maximized by extremely low DC resistance
• Hubbell high conductivity power receptacle
• Marinco high conductivity power plug
• Auricap High Resolution Capacitors used exclusively in filter sections
• All hand wired with 10 gauge equivalent power wire; no printed circuit boards
• Non-wearing silent high voltage transient suppression up to 20,000 AMPS
• Ceiling mount bracket
• Non-resonant damping
• Entire electrical circuit cryogenically treated
Realize the Full Potential of Power - With Power Factor Correction, RF/Noise Filtering and Transient Suppression
The adeptResponse elevates the performance of any audio/video system to new heights like no other power conditioner. In addition to superior power protection, the adeptResponse delivers the ultimate audio/video experience.
adeptResponse technology is considered to be the very best in providing clean ac power. The aR1p is designed like the renowned twelve outlet adeptResponse, aR12. It is hand built without the use of circuit boards or clip on connections. It is built only with premium quality high current components throughout.
The aR1p power conditioner is exceedingly unique and versatile; designed for single component applications like mono block amplifiers, receivers, video projectors and video displays. The aR1p plugs directly into a wall or ceiling power outlet (no power cord required). A simple high quality multi outlet power distribution system plugged into the aR1p can provide power conditioning for an entire audio or video system; albeit without component to component isolation featured in multi-outlet adeptResponse conditioners.
The aR1p adeptResponse provides surge suppression up to 20,000 amps. Whereas surge suppression devices like the ubiquitous MOV (Metal Oxide Varistor) are sacrificial devices and wear out over time, the aR1p surge suppression does not deteriorate. We have also found that MOV devices introduce grudge to audio and video signal. The surge suppression in the aR1p is entirely silent.
The aR1p employs wide bandwidth RF filtration. By reducing power line noise interference the adeptResponse provides a lower noise floor and blacker background, resulting in a higher resolution audio/video presentation.
The adeptResponse High Resolution Power Conditioner is a cutting edge design providing the best power conditioning possible without limiting dynamics. Since power must respond quickly and completely to the demands of program material we believe it is imperative that power conditioning components present the lowest possible impedance power path while providing wide bandwidth noise reduction. Conventional power conditioners simply cannot approach the bandwidth/impedance characteristics of the adeptResponse while still offering effective noise filtration and high voltage surge protection. Exclusive Audience technology achieves far greater performance for all audio and video components.
$395.00USD Shipped to anywhere in Canada and the lower 48!
I can also get these cryo treated if the buyer wants it done and I will do it at N/C.
Black Sand Cable
Re: Audience AR1P
« Reply #1 on: March 13, 2010, 08:36:40 AM »
SOLD!
