Eric, is the Apollo's startup delay while it scans the disc annoying to you, or do you just get used to it? I find the spinup of my cheap player annoyingly long.
And here's a question only the designer or an owner can answer: Is it possible to fast reverse from the beginning of a song through the break and into the end of the previous song on the Apollo? Many high end players can't do this, they just stop rewinding at the beginning of the song. I use that feature alot.
