I don't think people are worried about the price of a couple hundred for an upgrade, some people do that all the time. But there does seem to be a resistance to fuses (pun intended) as a legit upgrade. Same as it was with speaker wires a few decades ago and jitter a few years ago.
The resistance of the fuse element doesn't have to be the same, but the burnout behavior has to be within the standardized fuse spec. Maybe a silver fuse, with thinner element will blow the same time, but the lower resistance of the metallurgy provides some unknown advantage. Aluminum is a halfway decent conuctor, it's what brings your utility power to your service meter. We have copper in our walls because we care much more about wasting electricity to resistance than the power company does, an we care about reducing heat in our walls. But those are measurable, practical concerns for using different conductor metal. But in the space of a fuse where the conductor gage is adjusted to net a similar resistance, it becomes so small of a difference that it is hard to imagine it could make such an audible difference.
I once owned tube amps whose best sounding tubes were not great construction quality. When tubes blew they often took out fuses and sometimes worse so I had a stash of spare fuses and tubes until I finally gave up and sold the amps. But I was left with an unreasonable fear of expensive fuses.
My new SS integrated only needs one fuse, so it might be worth a try.
