Author Topic: Early Adopter dspNexus 2x8 has arrived!  (Read 2910 times)
« on: May 01, 2023, 10:52:32 AM »
The first Early Adopter unit dspNexus 2x8 has arrived from Danville Signal.  The accessories are the remote, S/PDIF cable and AC power cord.  The battery is separate from the remote since it is always on.  Nice and fresh with the 30 second battery install.
Will be getting the Magnetar II baffles back from rework for the new Radian planar driver as it is longer than the original mounting recesses.  Any future units have the CAD drawing updated for the new planar.
Looking forward to giving it a try as soon as parts are ready.
Re: Early Adopter dspNexus 2x8 has arrived!
« Reply #1 on: September 04, 2023, 08:31:00 AM »
Another Early Adopter dspNexus 2x8 is going out soon to use with a pair of GR-Research NX-Tremes with 3x12 servo subs.
Will work the customer through the measurements needed to replace the existing passive crossover with the DSP.
The easiest way to accomplish this is to make frequency and phase response electrical measurements at the output terminals of the existing crossover. then design the DSP crossover based upon those measurements.
« Reply #2 on: September 04, 2023, 12:50:24 PM »
 :thumb: :thumb:
