I bought a Audible Ilusions Modulas 2D for $400.
It is a very nice sounding preamp, especially for the money.
I am going to mod it....of course, and I am going to document all the changes and the percieved sonic differences I hear.
Later today I will post pictures of the unit bone stock.
I will perform one mod at a time in a certain order, photograph the mod and document what I hear. I am open to suggestions.
First mod will be the volume controls. The volume controls look like Alps blue, but may be something else. I ordered Dale Vishay stepped attenuators on eBay for $51 for the pair! with resistors!. Shallco 43 stepped attenuators with resistors are $348 from Michael Percy. These I am sure are the cats meow, but at the price of what the preamp almost cost me it seemed too over the top, even though I knew it would be the best volume control. I decided to do this on a budget, try to get great performance without buying the most expensive boutique parts.
Next up in mods will be power supply:
There are two sets of electrolytics that will be replaced. Since the unit was built in 1989 it probably is just good audio hygiene to replace these. I will do this in the 2 steps that are there. I will not use Black Gates which are impossible find and are not caps I like anyway, and I know I am in the minority here. Probably elna or Nichicon, or maybe some oil caps!
Next in the power supply will be the diodes, new diodes are .just faster and quieter, never a bad thing.
After the power supply I will look at some of the coupling caps, there are a lot of them in there and good quality caps can add up quick, I will address the ones I deem important and leave the phono section alone as it is not that great anyway.
Next we will look at hookup wire, this will be replaced with Neotech cabling. I am definetly open to suggestions on this topic.
Again it will be a slow process, and one at a time, allowing the parts to burn in, I usually replace a bunch of stuff at once, and we all know that is the wrong thing to do.
Hopefully it will turn out nice, perhaps it may get ruined, but there is alot to learned along the way.
Here is alink to the volume controls I bought, the first step for great sound in a preamp.
http://www.ebay.com/itm/Dale-23-Step-Ladder-Type-Attenuator-Potentiometer-POT-Log-100K-Ohms-Mono-x-2-/221094036357?pt=US_Home_Audio_Amplifiers_Preamps&hash=item337a3b4385Final step will be a deep cryogenic treatment of the whole unit
