Author Topic: Ice is nice!  (Read 22835 times)
miklorsmith
Re: Ice is nice!
« Reply #60 on: December 10, 2008, 08:28:04 AM »
All you have to do to try out an active preamp is plug it into the amp instead of the source - easy!  Theoretically I agree, a lesser-value resistor is better, but don't let that thought cloud this experiment.
Happy holidays to you too Shep!
Re: Ice is nice!
« Reply #61 on: December 10, 2008, 08:43:02 AM »
I agree with Mike, that's a great idea. If you really need a buffer to drive the amp, an active preamp will show you. If you have one lying around, easy to stick it in there to hear how it affects the bass transients. Cabling is not concern, any old crap will show you wnat you need to hear. You might find that a dedciated preamp might offer more subtlety than a mod driver stage.
Turn the volume pot all the way up to get the input resistance as low as possible and use the pre's VC.  Sorry, I can't remember whether you said you had a pre on hand.
Marriage of Figaro? That is a fun show!!
