Author Topic: Simple Mods for Shanling CDT200  (Read 11892 times)
carusoracer
« on: December 07, 2007, 07:34:12 AM »
I really like the sound of the player running off the tubes. It is pretty good player but I like things that have been tastefully modded within reason. I know several firms have made changes to the player but I have not been able to hear them.
What I'm seeking is help with the changes to the OP Amps and some transistors and diodes along with basic cap changes. I'm not experienced enough to do and want to know who can do this kind of work with in a reasonable time period and decent price. I only want to do some minor changes as I can not swing doing a major transformation.
Any help appreciated, Thanks in advance
shep
Re: Simple Mods for Shanling CDT200
« Reply #1 on: December 07, 2007, 09:11:27 AM »
The best site on the planet is this: http://www.diyaudio.com/. Join up and address the crowd! seriously hard-core and dedicated. Which doesn't mean you wouldn't have a polite intelligent response...
The thread dedicated to my player, and ones like it, is now over 600 pages! Don't be put off! If you were in the UK I would direct you to http://www.sercal-electronics.co.uk/. The head guy is one of the gurus of the DIY site, digital section. There are at present two schools of thought about op amps and basically 2 great ones; they are not expensive and if you're lucky, your player will have the type you simply remove and plug in the new ones (carefully). BIG sound change...after min. 150 hours burn in. Caps are trickier, requiring soldering. Ditto diodes (Schotsky being the hot name in diodes). If you can get some good feedback from the Diy site, order parts (some people will graciously give you a brace of op-amps since they were given out like peanuts by the manuf. to stimulate interest) and find a local tweek person with the knowledge to install for you without sending it somewhere. My Marantz went from being a fairly pedestrain old-style player to something quite extrordinary for around 100$ (not including shipping and 2 burnt-out laser assemblys...one due to age the other due to my fault) A fairly simple tweak is to cover as much surface with bitumin self-stick sheets/damping and replace fuses with audiophile grade or for the seriously neurotic, like me, hardwire fuses holders. Hope this helps. Beware! once you start down this road, there's no turning back.
