Author Topic: GALLO SPEAKERS  (Read 5189 times)
Offline zerojeff
  • Newbie
Re: GALLO SPEAKERS
« Reply #15 on: February 29, 2020, 07:10:00 AM »
Barry, mine were aluminum and boy I wish I had those back. Paired with upgraded Quicksilver 8417’s they were very intimate and lifelike.
Offline toobluvr
Re: GALLO SPEAKERS
« Reply #16 on: February 29, 2020, 07:47:33 AM »
I think the Aluminum enclosure Solo, was probably the ultimate speaker Anthony designed. I think the TWW configuration of the early Reference designs, and their minimalist (lack of a) crossover, combined to cause a very slight out of phase with the tweeter and lower woofer. The more minimal TW design of the Solo escaped this. And the Aluminum enclosure just had a more clear and transparent sound than the Polyethylene offered.
I don't know anything about the Polyethylene enclosure you mention for the Nucleus model that IIRC was available alongside the Solos circa mid to late 1990s.  Same concept / design, just with an additional woofer sphere and higher in the Gallo lineup.   Never seen the poly in person nor in a photo, and I've never heard of it nor read about it.
Both my pair of Nucleus Ref 2s (the 2 ball model)  had aluminum spheres.  As did another local pair of Ref 2s that I was in the same room with.
And like Zerojeff, there are times that I too regret selling mine.
« Last Edit: February 29, 2020, 07:52:19 AM by toobluvr »
Re: GALLO SPEAKERS
« Reply #17 on: February 29, 2020, 11:47:31 AM »
  I just shake my head every time I hear my Buddy's Spheres modified by Mapleshade. Lifelike is correct. It is an ALL Maplshade system from TT/PRE/ DAC to Amps using Omega Micro Cabling. Hi Sydney.
Re: GALLO SPEAKERS
« Reply #18 on: March 02, 2020, 10:14:36 AM »
Well, there's a photo of the poly enclosure Solo in my earlier post on this thread. Note that you call the speakers "Ref 2s", the 2 was for the second iteration, not 2 spheres. I have the original add flyers form both the early and second gen Gallo speakers.
I purchased my early versions directly from Anthony's basement in Brooklyn in '92 or 3.  I had my references upgraded to Ref 2s at his modest factory in Brooklyn in '95 or 6, as things were going well, and he'd moved out of his basement. I can try to scan the flyers and post them here. I may have some more personal pictures as well, but as that was pre digital era photography, I may have difficulty putting my hands on the pix.
P.S. The naming convention was Nucleus Solo (single sphere) and Nucleus Reference (2 spheres).
There was also a Nucleus Minor, that used a concentric MidWoofer-Tweeter (similar to many KEF speakers. I think it was actually a KEF driver).
« Last Edit: March 02, 2020, 11:17:19 AM by Barry (NJ) »
Re: GALLO SPEAKERS
« Reply #20 on: March 02, 2020, 05:20:47 PM »
Here are the brochures I mentioned.
The early polyethylene version of the speakers...
Early Gallo 1 by Barry, on Flickr
Early Gallo 2 by Barry, on Flickr
Early Gallo 3 by Barry, on Flickr
The later aluminum version...
IMG_20200302_195131 by Barry, on Flickr
Offline Folsom
Re: GALLO SPEAKERS
« Reply #21 on: March 02, 2020, 07:29:33 PM »
I dig the box racks.
