Author Topic: Monopole Speaker Room Location  (Read 5007 times)
Re: Monopole Speaker Room Location
« Reply #15 on: January 04, 2020, 11:50:35 AM »
I have used CARA2.2 Plus for many years to get good ideas of where to start with speaker placement.  It has worked well for me.
You can do a simple model or complex model of the room and speakers to have it do an optimization for placement.
It allows stereo and multi-channel systems to be built.
http://www.rhintek.com/cara/cara21desc.php
   Thank you Hal. Probably by best bet besides my ears.
Offline AJ Soundfield
    • Soundfield Audio
« Reply #16 on: January 04, 2020, 12:57:52 PM »
To be honest I was looking for a valid point for of placing or not placing monopole less than one mtr from front wall
If its say a large CD/Horn type speaker, then its probably ok. If it's a narrow baffle wide dispersion cone n domer, probably not.
Both are "monopoles".
or over 2 mtr
If its say a large CD/Horn type speaker, with large vertical spaced drivers brought closer to you,  then its probably not ok. If it's a narrow baffle cone n domer, probably fine.
Haven't even touched on room or tastes yet. :)
Loudspeaker Manufacturer
