Author Topic: Your favorite 12AU7?  (Read 6156 times)
Offline Brap
Re: Your favorite 12AU7?
« Reply #30 on: April 25, 2021, 10:31:09 AM »
That is beautiful!  FYI, I use right angle connector on my front RCA inputs to route the input cables around the front and then under the outside edges of the rubber feet t o the back of the amp. Makes a cleaner look.  NOTE- the ones that have a square corners do not fully turn parallel with the top of the amp so look for one that are more rounded.  I had to do some filing on the gold plated corners to allow these to turn a full 90degree.
Fritz Carrera 7 Be
VTA ST-70
Parasound Halo P5
Oppo 105
Rega P3
Ortofon Quintet Bronze
Cambridge CXN streamer
Teac 3340S
Anticables 3.1
Offline toobluvr
« Reply #31 on: April 25, 2021, 10:40:53 AM »
John, try to find some Reflecktor 6P3S-E for your 6L6 amp if it can take them (should be able to if it can handle 6L6GCs). The best of the 6L6/KT66 family I've heard (including RCA black plates & Sylvania 6L6GCs & Shuguang & Genalex re-issue KT66s). Fantastic tubes, they've been my favorite power tube for several years now.
Another apology for an off topic post.     But tubes!
Got 'em, Rob -- the coin base version.  Thanks!   :thumb:
Will Vincent included them when he returned the amp to me after a repair.  He said they are his faves in that amp.
« Reply #32 on: April 25, 2021, 10:49:03 AM »
Trying to visualize what you’re saying... Can you reword it?
Offline toobluvr
« Reply #33 on: April 25, 2021, 11:08:11 AM »
I think he's saying this......
The RCA inputs on his VTA ST-70 amp are so closely spaced that when he rotates the adapters down so that he can kindof drop the IC and run it under the bottom front corners of the amp, the corners of the "squarish" adapters crash into each other, preventing this rotation.  So he filed off the corners.  If you get the "roundish" ones, no filing needed.
But I could be wrong.  :lol:
These photos will help to visualize.
VTA amp:
http://www.tubes4hifi.com/VTA70a.jpg
"squarish" RCA adapters:
https://images-na.ssl-images-amazon.com/images/I/81v0QMNBQwL._SL1500_.jpg
"roundish" RCA adapters:
https://images-na.ssl-images-amazon.com/images/I/41IZOeeISrL._AC_.jpg
« Last Edit: April 25, 2021, 11:25:55 AM by toobluvr »
« Reply #34 on: April 25, 2021, 11:46:37 AM »
VTA amp:
Thanks, John. That is very helpful  :thumb:
« Reply #35 on: April 25, 2021, 10:50:49 PM »
I am a 12BH7A convert.
I find more consistency between various 12BH7A than various 12AU7, no matter their heritage.  These days I am looking for repeatability of excellent sonics than ultimate WOW factor that is fleeting.
12BH7A tubes have a universal "rightness" to their sound.
Offline Brap
« Reply #36 on: April 26, 2021, 05:06:25 AM »
toobluvr -- stated much more succinctly!!
Fritz Carrera 7 Be
VTA ST-70
Parasound Halo P5
Oppo 105
Rega P3
Teac 3340S
Anticables 3.1
Offline toobluvr
« Reply #37 on: April 26, 2021, 08:04:49 AM »
Interesting.  Is it a direct drop-in replacement for 12au7?
« Reply #38 on: April 26, 2021, 08:08:49 AM »
It's what I use in the outside slots on my Moscode 401 amp.
