Author Topic: FS: Six Moons reviewed Accuton & RAAL Symphonia 7R and 72R  (Read 3969 times)
Offline Clearwave
    • Clearwave Loudspeaker Design
The Symphonia speakers are about refinement and taking music reproduction to a level that can only be achieved by using state-of-the-art drivers and blending the inherent strengths of eachdriver with art and science. Amazingly, there is only 1 capacitor inseries on the pure ribbon tweeter circuit. The result is breathtaking highs and transparency. The ceramic woofers are holographic and have tight focus and depth in their presentation. One would think that you might need a matching ceramic tweeter to maintain accurate voicing through the full frequency range, but this is not the case with the Symphonia Series. The drivers blend seamlessly and build on the strengths, not weaknesses. The end product and presentation may very
well take your breath away.
The Symphonia speakers have a custom sandwich layered non- resonant front baffle with a solid hardwood layer for driver de-coupling, along with extensive bracing. The drivers are flush mounted level to the front baffle to eliminate edge diffraction, and the driver openings have chamfered flares at the backside of the opening to eliminate early reflections inside the box. The Symphonia Series features high quality Supra wire, state-of-the- art drivers, point to point crossovers, gold plated high purity copper Cardas binding posts, and multi-density dampening materials to absorb standing waves.  We use Mundorf resistors, Clarity Cap MR (signal path), ESA, and PX caps, and heave gauge copper inductors for the purest sound transmission. No detail is left unfinished.
Read some feedback by Stereophile: Teamed up with Wyred 4 Sound, the Symphonia 72R was making great sound at the show.
www.stereophile.com/content/wyred-4-sound-solid-yet-delicate
Read the rave review at Six Moons magazine where the bigger brother Symphonia 72R is compared to speakers costing over $20k.
www.sixmoons.com/audioreviews/clearwave/1.html
I have the following for sale in new condition:
Symphonia 7R bookshelf speaker is $4650US
Symphonia 72R tower is $7200US both featuring:
--Amorphous core RAAL OEM tweeters
--Accuton 7" bass drivers
--Point to Point wiring
--Engraved binding post plate/tweeter faceplate
In stock or soon to be in stock:
7R-- Black oak, Silver custom faceplate
7R-- Hand rubbed medium cherry lacquer, Silver custom faceplate
72R--Mission Oak, Silver custom faceplate
72R-- Curly Cherry, Silver custom faceplate
I will ship from E Rochester to areas other than NY, Michigan, and CA.  If you are in one of those states, I will put you in touch with our distributor for your area.
Thanks for your interest. For more info go to the new Clearwave Loudspeaker Design website here:
www.clearwavespeakers.com
Custom finishes available as well like this high gloss walnut 7R:
Clearwave Loudspeaker Design  www.clearwavespeakers.com
