Author Topic: For anyone using Thunderbird  (Read 4028 times)
shep
« on: June 14, 2011, 09:13:10 AM »
I foolishly updated Thunderbird yesterday to the offered 5.01b build. I have never had any issues with new builds from Mozilla but this time I got a Lulu...namely that imbedded links in mails will not open the browser (any browser). I assume this is a bug and will be sorted in time but if anyone else has encountered this I would appreciate confirmation. Actually this sucks bigtime. And what's worse is that I can't roll back to a previous version.Thanks
I tried installing another version and the problem is the same. Very odd.
« Last Edit: June 14, 2011, 09:18:50 AM by shep »
Re: For anyone using Thunderbird
« Reply #1 on: June 14, 2011, 11:27:43 AM »
My Thunderbird client says version 3.1.10.  Then under that it says:
Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.9.2.17) Gecko/20110414 Lightning/1.0b2 Thunderbird/3.1.10
Since you say ver 5.01 maybe you have upgraded your browser, not your email client (or both?) Firefox has a version 5 beta now, and it has some compatibility issues with previous plugins stable under ver 4.
http://blog.mozilla.com/addons/2011/05/21/firefox-5-compatibility-bump/
Try setting default browser to something other than Firefox to see if email links work again.  I use Chrome and my links work fine from emails in Thunderbird 3.1.10.
shep
« Reply #2 on: June 14, 2011, 01:35:39 PM »
Both firefox and Thunderbird are the latest versions and I suspect you're right. I'll try Chrome and see what happens.
Nada. I found that there are no plugins in the data base whatsoever so obviously it can't do anything other than recieve and send mail. This is totally weird. Obviously I shouldn' have updated to this beta build  :duh
« Last Edit: June 14, 2011, 02:04:06 PM by shep »
« Reply #3 on: July 28, 2011, 05:08:38 AM »
Did you get this fixed shep?
My Thunderbird is asking for an upgrade to ver 5.0 (release version) Should I do it?
djdube525
« Reply #4 on: July 28, 2011, 08:12:16 AM »
Shep,
If you decide to roll back to an earlier version, this may be helpful.
Here's a repository of older versions of Thunderbird.
Dave
